04-23-2020, 10:26 PM | #1 |
Transfer Case Wire Question
I have a 1978 K25 that was a TH350/NP203. It was converted to a TH400/NP205. My question is what is the purpose of the wire that went to the 203-a dash indicator? If so, is there a spot on the 205 for this wire; or should I remove it?
Thanks, Marvin |
04-23-2020, 11:39 PM | #2 |
All about them K’s
Re: Transfer Case Wire Question
If it’s the same wire I’m thinking about, it was used to indicate on the dash that the truck was in 4x4. The eary 205s dont have this feature but I believe the later 73+ cases had the option for the light, I don’t believe all the later cases got the light/switch though. I do know the 4x4 shift rail is different between the cases with the light switch and with out. Any idea approximately what year your 205 is?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
04-23-2020, 11:42 PM | #3 |
It’s a later 205, somewhere between 83-87 l believe.
Thanks for the reply! Last edited by 1977ChevGMCK2025Fan; 04-24-2020 at 12:06 AM. Reason: Spelling error |
04-24-2020, 12:33 AM | #4 |
The switch goes in the shift rail detent spring/ball/plug hole. I have a 205 with switch on the bench now. I'm not sure the switches are available. Might try a micro-switch on the linkage somewhere.
I googled it... https://torqueking.com/product/30048...icator-switch/ Last edited by franken; 04-24-2020 at 12:41 AM. |
04-24-2020, 08:45 AM | #5 |
Thanks Franken. It looks like I need to go searching for the male plug in wire. This will probably be hard to locate as 205s are not near as common as 203s.
Marvin |
04-25-2020, 10:38 AM | #6 |
It looks like A standard GM weather pack connection. I would just buy a switch and go to the junkyard. It looks about like the under hood plugs from an 88 up TBI truck.
