Old 04-09-2020, 11:37 AM   #2151
cornerstone
cornerstone's Avatar
Re: How to: Ruin a perfectly good C10
How much clearance are you allowing around the tightest places for your driveshaft? I'm in the middle of this now also and not sure if I should trim my cab floor also. It looks like I've got about 3/4 of an inch after I install my driveshaft.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-09-2020, 01:32 PM   #2152
SCOTI
SCOTI's Avatar
Bottom the suspension out completely & make sure the d.shaft doesn't contact anything. If it does, trim things back until it doesn't. I usually build things w/a 1/8" thick (yard stick) spacer to pad my clearances.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-09-2020, 06:00 PM   #2153
cornerstone
Thanks Scoti, that sounds like solid advice. I was thinking I'd need at least an inch, but I like your plan better.
Brian
Old 04-12-2020, 08:28 PM   #2154
gringoloco
A guy with a truck
gringoloco's Avatar
Hump is done. Not metal-worked to perfection, but doesn’t need to be. I got her finish welded and knocked down smooth, shot with a coat of self-etch on the top and undercoated the bottom, then bolted her in with a bead of window weld cord to seal. Looks and fits like it belongs and has taken the first layer of sound deadener.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-12-2020, 08:32 PM   #2155
gringoloco
A guy with a truck
gringoloco's Avatar
I buried mine on the bumpstops then allowed minimum 3/8” all around. I like a little bit of wiggle room and am saving space for a possible driveshaft safety loop. I think if you have 3/4” of space, you are way good.
-Chris
Old 04-12-2020, 08:33 PM   #2156
SCOTI
SCOTI's Avatar
Well done.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-13-2020, 09:12 AM   #2157
smbrouss70
smbrouss70's Avatar
Nice!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-14-2020, 02:52 PM   #2158
Joseog83
Joseog83's Avatar
Awesome!
'91 Full-Size Rebuild:
http://67-72chevytrucks.com/vboard/s...d.php?t=751504
Joseog83 is offline   Reply With Quote
Old 04-14-2020, 11:07 PM   #2159
gringoloco
A guy with a truck
gringoloco's Avatar
Well done.
Originally Posted by smbrouss70 View Post
Nice!
Originally Posted by Joseog83 View Post
Awesome!
Thanks dudes!
I moved to the engine bay for a bit while I wait for more sound deadener and new carpet to arrive in the mail. I decided that I wanted to delete the knock sensors and oil filler cap, simply because they were an eyesore to me. I used a smooth valley cover, and drilled a hole for a fixed-orifice PCV, which more closely mimics the late model LS engines from the factory, but kept it hidden behind the intake.
Need to paint my air cleaner and put everything back together and I think I may actually be done with this engine (for now), maybe?...
-Chris
Old 04-14-2020, 11:40 PM   #2160
cornerstone
You're gonna confuse all sorts of folks when you pop the hood. Just when I'm convinced your LS is the coolest... you make it cooler.
What kind of deadener are you ordering and where? I need to get some more too. So far I'm leaning toward Noico 80 mil on Amazon... 36 sq. ft. for 67 bucks
Brian
Old 04-15-2020, 07:50 AM   #2161
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks man Sound deadener, I was looking at Noico, but I ordered 80 mil “Siless” brand from eBay, 36 sq ft for $49. The cheap stuff all seems to be made in the same place, somewhere in the Ukraine. Reviews on this were just as good as any of them, but at a significant discount (even cheaper than Peel and Seal from Lowes).
-Chris
Old 04-15-2020, 09:39 AM   #2162
aggie91
I'm just glad to be here!
aggie91's Avatar
I used the Siless 80mil stuff too. I got it off Amazon. Mine looked a bit different than yours in the picture above. Mine had squares embossed on the foil side. I used a Noico metal roller to put mine down. The roller had a grooved pattern that left impressions in the foil to help show where you had rolled over the material.
So far it seems to work well, my son has been driving the truck with it installed, but no carpet and it has made a difference over the stock jute pad and carpet.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-15-2020, 02:28 PM   #2163
gringoloco
A guy with a truck
gringoloco's Avatar
Good to hear it’s decent stuff, looks like a nice install there. What you see in the pictures above is Peel and Seal, which has worked well for me in the past, but I plan on doing most of the cab, so it made more sense (and fewer cents) to order a box of the Siless.
-Chris
Old 04-19-2020, 06:07 PM   #2164
gringoloco
A guy with a truck
gringoloco's Avatar
Lots of time spent doing things which amount to minor progress The Siless sound deadener arrived and laid out nicely; I covered the floor and rear cab wall and am saving a few sheets to apply inside the doors when I tear them apart for new seals. Still need to hit the whole business with the seam roller to make it permanent. Carpet soon???
Also spent an embarrassing amount of time cutting, bending, drilling, and painting a universal driveshaft safety loop to fit just behind the front u-joint. I don’t ever anticipate being fast enough to need one per NHRA standards, but it makes me feel better with the driveshaft spinning only inches beneath my ass...
-Chris
Old 04-19-2020, 11:19 PM   #2165
KMC3420
KMC3420's Avatar
Haha, nicely done! The loop looks top notch.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 04-19-2020, 11:20 PM   #2166
kehstr
kehstr's Avatar
I second this!!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 04-20-2020, 08:59 PM   #2167
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by kehstr View Post
I second this!!
Thanks guys! Happy to be done with that and moving on
-Chris
Old 04-21-2020, 09:48 AM   #2168
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Killer job, the smooth valley cover makes a huge difference. Are you going to relocate the knock sensors or delete all together?
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 04-21-2020, 09:53 AM   #2169
shearjs
shearjs's Avatar
Where did you end up mounting your Term X computer? I don’t remember seeing it anywhere.
shearjs is offline   Reply With Quote
Old 04-21-2020, 08:46 PM   #2170
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, I think it looks a LOT better. Knock sensors are deleted for now. The Holley programming has them turned off and it is a bit of a programming puzzle to get them working properly with an aftermarket cam. I’m not against adding them back later, probably to the sides of the block.
It’s just sitting on the passenger floorboard for now, in a snake’s nest of temporary wires. I have yet to decide if it’s going under the seat or in the glovebox. Guess I need to figure that out before I lay carpet...
-Chris
Old 04-21-2020, 11:56 PM   #2171
SCOTI
SCOTI's Avatar
My thought is whatever is easiest.... to access.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-22-2020, 06:37 AM   #2172
shearjs
shearjs's Avatar
I should have looked a little closer and I would have noticed your snake nest. I’m getting close on my wiring now and I think I’m shooting for under the seat on the drivers side.
Old 04-23-2020, 01:36 PM   #2173
gringoloco
A guy with a truck
gringoloco's Avatar
I’ve laid mine in the under-seat area on the passenger side and it seems doable, with relocating a few of the fuse and relay locations. I don’t want to cut any wires if I can avoid it, as it voids the Holley warranty, though I think I should be able to do it with some creative re-looming.
-Chris
Old 04-23-2020, 02:02 PM   #2174
halfstep
GringoLoco:
Thanks for sharing your build - the information and ideas from you and others really helps.
Question:
Assuming you're connected to the engine, how far does the Terminator X harness/ECM extend into the cab - or how much length do you have once past the firewall?
Thx.
halfstep is offline   Reply With Quote
Old 04-24-2020, 07:46 PM   #2175
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by halfstep View Post
GringoLoco:
Question:
Thx.
No worries, this is why we share The Termi-X harness extends around 4 feet beyond the firewall into the cab, just about enough to put the ECM under the seat, or to have to coil the harness up to put it in the glove box.
-Chris
