04-30-2020, 08:09 PM | #1 |
trans dipstick question for 4l80e, Lokar style firewall mount
So I ordered this lokar firewall mount dipstick. I'm skeptical because a dipstick is not supposed to lay on the bottom of the pan? I ordered it specifically for my 4l80e and the pan has not been modified or changed. When I insert it I can feel it make contact. The stick is flexible plastic and it sure feels like it is making contact with the bottom of the pan and then flexing along the inside of it. This is not normal is it?
I don't want to take any chances. I spent the money on seals, trans2go shift kit and a stall converter from circle d. Last thing I want is to ruin the trans somehow from not filling it properly. on a side note: I forgot to fill the converter before bolting the trans to the engine. I was worried I should pull it all apart, but a friend said I could fill the pan, crank over the engine (disable it to run, just crank it over), let the pump pull the fluid out of the pan into the converter, fill again, and do this a few times until the pan stops draining. Does this sound okay? |
04-30-2020, 10:47 PM | #2 | ||
Roto Reuter thats the name...
Re: trans dipstick question for 4l80e, Lokar style firewall mount
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-01-2020, 08:56 AM | #3 |
yeah, took a measurement and this definitely isn't correct. I guess I didn't buy (purchased this a while ago) Lokar brand and that's what you get. It's a plastic dipstick and obviously WAY too long. Going to have to figure out how long it should be and cut it down a little.
05-01-2020, 09:19 AM | #4 |
Almost Satisfied
I tried several options for my 4L80e, but didn't want to mount something on the firewall. Ended up going with the Summit AAF-ALL69118. It fits pretty well. Had to fab a bracket to get it to bolt to the back of the head. Wish I had a better pic for you.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
05-01-2020, 09:43 AM | #5 |
that looks really good. I'll probably do that same thing now. I don't trust this firewall mount stick. I'm afraid to use it as a guide for properly filling my trans
05-01-2020, 10:23 PM | #6 |
Here is the Lokar firewall mount trans dipstick that I used for my 4L60E. I hope it's correct.
05-02-2020, 12:11 AM | #7 | |
FWIW, I've seen this method in 2 places, and is how I just filled mine:
From https://www.hotrod.com/articles/caus...7j90czdp_pSgU: Quote:
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
05-02-2020, 11:50 AM | #8 |
wow. very informative read. just what i needed. guess now I can modify the dipstick to be accurate.
