Old 05-02-2020, 01:01 AM   #1
prodjay10
1999 lm7
Are the 99 lm7’s the same as 2001 thru 2006 or so?
prodjay10 is offline   Reply With Quote
Old 05-04-2020, 03:39 PM   #2
MDPotter
MDPotter's Avatar
Re: 1999 lm7
No, they made a few small changes internally. HP increased at some point but the biggest difference is that drive by wire was phased in around 2003/2004.
https://help.summitracing.com/app/an...7-engine-specs
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-04-2020, 04:26 PM   #3
prodjay10
Would this be a good option for an LS swap?
Old 05-04-2020, 04:34 PM   #4
MDPotter
MDPotter's Avatar
Re: 1999 lm7
It depends on a few things.
Condition-Is it a complete, running engine? How many miles? Rusty/leaky/dirty? It's getting hard to find Gen 3 engines with low miles in good shape (less than 100k).
Price-GM made millions of these engines so they're not hard to find and are cheap. 2nd only to the 4.8, these have to be the cheapest LS engines you can buy. How much is the seller asking?
Intended use-what are you putting it in? The LM7 doesn't make an overwhelming amount of power, but still a huge improvement over an old tired small block. If it's a worn out engine and you want to build an engine, it's a good starter with the iron block.
Old 05-04-2020, 05:37 PM   #5
prodjay10
71 c10.
$400 with about 150k miles. Probably leaky. It’s replacing a 2002 lm7
Old 05-04-2020, 06:03 PM   #6
MDPotter
MDPotter's Avatar
Re: 1999 lm7
That's not bad. I would look at it in person and drive the vehicle if possible. Is it being pulled out of a wrecked vehicle or what?
Old 05-04-2020, 08:24 PM   #7
prodjay10
Buying from a wrecking yard. It’s already pulled
