Old 05-10-2020, 01:10 PM   #1
flashed
Frame and Suspension Questions
Just recently got my 70 stepper back from Rust Repair and paint blending , keeping it Patina , the body is now ready for the rest of the build .
Im going to take it off the frame next , pretty easy since all bolts holding it on are new .
Im going to take the front and rear suspension off the frame , never done this before and have the frame sand blasted and painted or powder coated , undecided on that .
Where do I buy replacement bushings for the rear suspension (best quality brands) and what are they called ?
Where do I buy the A frame bushings for the front (best quality brands ) ?
Any ideas and tips are much appreciated .
flashed is offline   Reply With Quote
Old 05-11-2020, 10:18 AM   #2
SCOTI
SCOTI's Avatar
Re: Frame and Suspension Questions
Moog 'Problem Solver' series bushings are top tier quality.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-13-2020, 01:41 AM   #3
mongocanfly
mongocanfly's Avatar
And my 2cents...powder coat is not the best idea on a frame...paint is much easier to repair if you get a chip or have to drill/weld/cut on the frame.
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-13-2020, 10:01 AM   #4
SCOTI
SCOTI's Avatar
I PC'd my frame w/zero regrets. For a driver type of build, you can blend in rattle can repairs w/o issue on the standard Semi or Low Gloss Blacks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-13-2020, 03:17 PM   #5
Ziegelsteinfaust
For the front PST poly graphite have been a personal favorite for a long time. Not sure I would run them on a trailing arm truck if yours is so equipped
Ziegelsteinfaust is offline   Reply With Quote
Old 05-13-2020, 08:33 PM   #6
mongocanfly
glad you had good luck with pc Scoti.. ive had some good luck with pc and some turn out horrible...id get a reputable coater to do it though
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-13-2020, 09:40 PM   #7
SCOTI
SCOTI's Avatar
Truth. Definitely don't cheap out if taking that path.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-13-2020, 10:07 PM   #8
flashed
My truck does have the trailing arms , hoping to set the body off the frame very soon so I can tear into the frame . Probably going to sandblast and paint it . A neighbor does sandblasting and a buddy is going to paint it for me . Be a lot cheaper and I can spend money elsewhere . Like all my toys , this will be a driver .
Old 05-13-2020, 11:15 PM   #9
Ziegelsteinfaust
If you like a firmer suspension like I do. I would run PST poly graphite in front.
Then for the rear either high quality rubber bushings or doing something like Johnny joints. The Johnny joints I have read are decent for the street, but I have no personal experience. But I would use PST polygraphite bushings in the pan hard.
If your fine with factory there rubber kits are top notch too
Old 05-15-2020, 08:59 AM   #10
68Stepbed
68Stepbed's Avatar
What's the overall plan for the truck, John?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
