Old 05-08-2020, 08:47 AM   #1026
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: What did you do to your Blazer/Jimmy today?
looking very good
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-09-2020, 08:48 AM   #1027
SoCoC10
SoCoC10's Avatar
Originally Posted by Ptjsk View Post
Just keeps getting better!
Thanks! Few details left and she’ll be ready for a new owner.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 05-09-2020, 04:06 PM   #1028
wesmigletz
wesmigletz's Avatar
Prepped the front floor pan and the bed pan. After the front floor pan was fitted by the gy doing my metal work, I brought it home, shot it in epoxy primer, then coated the bottom side in Rustoleum Semi-Gloss, reduced with acetone and used an alkyd enamel hardener. It came out glossier than I would have liked. The top of the front floor is Kirker Semi-gloss Synthetic Enamel with a hardener. The rear bed floor is just in epoxy primer.
BTW, I'm tempted to paint the rear bed pan while it is out. I will be replacing both bedsides. Do you think I can paint it now, then mount it and install bedsides without too much damage to the paint? It is hard for me to reach the middle areas to paint...
This is the expected body color, TCP Global Jet Black. I shot it the other day while painting my son's bike.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 05-16-2020, 08:31 PM   #1029
kmg123
Refinished the center console and installed a radio inside.
kmg123 is offline   Reply With Quote
Old 05-16-2020, 10:01 PM   #1030
SoCoC10
SoCoC10's Avatar
Replaced the rear wheel center caps with new stickers.
Old 05-16-2020, 10:50 PM   #1031
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Swapped incandescent for LED courtesy lamp bulbs.
Old 05-16-2020, 10:52 PM   #1032
Ptjsk
Wow! Looks bright, and the truck looks clean inside there!
Pat
Ptjsk is offline   Reply With Quote
Old 05-16-2020, 10:54 PM   #1033
Ptjsk
Primed, blocked and primed again!
Pat
Old 05-16-2020, 10:54 PM   #1034
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I’ve been doing a lot of tinkering lately with the doors open so wanted bulbs that didn’t get as hot. The light is a lot brighter.
Old 05-17-2020, 12:56 AM   #1035
maldo
maldo's Avatar
New shoes for 2020
maldo is offline   Reply With Quote
Old 05-17-2020, 08:41 PM   #1036
OldCreek
OldCreek's Avatar
Thinking about this, too, for the same reasons. I just like the soft white lights so much better... just gotta get the right bulbs.
Washed and “waxed” today with some Meguiar synthetic product...I probably should have clay bar/waxed it instead.
Hosed out the interior....K/5’s are awesome!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 05-21-2020, 07:32 PM   #1037
Ptjsk
Paint day!!!
All that prep work finally paid off! Looks straight and correct!
Pat
Old 05-21-2020, 08:03 PM   #1038
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Loaded onto a flat bed for trouble shooting a new ticking sound coming from the original 350, which hasn’t yet clocked 600 miles. Looks like a sheared valve keeper and a chipped valve. Doh!!
What’s likely fix? Pull engine, pull head, replace valve?
Old 05-21-2020, 11:29 PM   #1039
Ptjsk
Damn! That sucks Pete!
I know I sure seem to have a lot of problems with newly rebuilt motors too.
Most of my problems have centered around comp cams roller lifters.
Sorry you're going through this!
Pat
Old 05-22-2020, 07:29 AM   #1040
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Pat. This too is a roller hydraulic cam. Hope to have more info later today.
Old 05-22-2020, 11:31 AM   #1041
Ol Blue K20
Man that sure does suck. Is there a warranty from your builder?
Dale
Old 05-22-2020, 12:37 PM   #1042
Blazer690
Blazer690's Avatar
Found a lowered bench seat bracket for my 2wd blazer years ago.Readjusted the pas seat to match. Valve fix=make a sparkplug to air fitting then tdc and 100 lbs.push the spring down replace the retainer (maybe new) and cross your fingers,not to much to loose. I'v done it with a gismo that bolts to the rocker stud.
Blazer690 is offline   Reply With Quote
Old 05-22-2020, 02:04 PM   #1043
litebulblsc
litebulblsc's Avatar
A lot to lose, when you drop a valve
litebulblsc is offline   Reply With Quote
Old 05-22-2020, 09:30 PM   #1044
Ryanz
Ryanz is offline   Reply With Quote
Old 05-22-2020, 09:36 PM   #1045
Ryanz
Just got my auto wrecker Steelies and Dog dishes on. Widened to 8 inches, painted and 10.5 x33 BF Goodrich.
Old 05-22-2020, 09:53 PM   #1046
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Dale thanks. Clock ran out on that a while ago. I’ve been talking with the owner of the machine shop though. He’s a genuine guy and every bit the old, old school machinist you can imagine. Were I still in ABQ I’m sure he’d work with me to make it right.
Old 05-22-2020, 09:53 PM   #1047
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks great!
Old 05-22-2020, 10:50 PM   #1048
Ptjsk
Definitely one of the top Blazer's I've seen. Looks incredibly good!
Going to have to go with Steelies on the Jimmy.
Pat
Old 05-22-2020, 11:14 PM   #1049
Ryanz
Pat
Thanks a ton Pat. I was inspired by Deadhead’s look! He helped me with the sizes.
Old 05-22-2020, 11:17 PM   #1050
SoCoC10
SoCoC10's Avatar
New grille and trim rings.
