4.8/5.3 to 91 5 speed.
I have a disassembled 91 gmc RCLB 4.3 5spd. Contemplating swapping to 5.3 or 4.8. Cruiser daily. Is this doable?
Is there a post containing parts lists? Engine mounts Harness. Is there a pin out to combine and keep all gauges etc working? I know trans isn't best.. I just want a daily that is not a v6 |
![]() ![]() Join Date: May 2015
Re: 4.8/5.3 to 91 5 speed.
I assume you have a nv3500..? But putting a LS in front of it wont be cheap...you may be better off getting a complete engine/trans pullout and swapping to a auto...
The gauges are Independent of the LS harness.. Not sure on engine mounts, but I bet they're out there for a s10
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-03-2020 at 06:27 PM. |
![]() Join Date: Aug 2004
Look here for some flywheel and clutch ideas
https://ls1tech.com/forums/conversio...-ls-motor.html
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
![]() Join Date: Aug 2018
I dont have a parts list but off the top of my head, you will need a flywheel for a 2001 or so standard shift silverado, the pressure plate and clutch from your truck will work on the flywheel but you will have to remove an alignment dowel. You will need a ls7 pilot bearing for the extended pilot bearing that is available from summit racing. As for the mounts, you can use dirty dingo sliders for the ls swap. On the speedo, keep the wire pigtail from your original harness and it can be spliced into the ls harness to pins 20 and 21 on the red or green connector from a silverado harness. And pin 50 on the red or green connector will go to your speedometer. You can cut your harness down yourself using lt1swap.com using his pinouts and all the gauges in your truck will work flawlessly if hooked up correctly. For oil pressure, save the original sensor from the v6 and get an adapter to fit it to the ls block, for the temp, I use a 98 fbody camaro or transam sender, part number 12551708. This is a 3 wire sensor, 2 wires go to the computer and the third goes to the gauge. That is the simplest way I know to get it to work. The volt gauge should just work. Send your computer out to Brendan at lt1swap.com for a vats delete and you should be good to go. Thats the basics of it and the cheapest way I know to get you up and going on a ls swap.
#5 | |
Thank you.. I will be looking for an engine. |
