05-18-2020, 03:48 PM | #1 |
HEI distributor problems
I've been fighting a HEI problem ever since I've had my 68 C10 done. I bought a new AC Delco distributor when I built the 350. I have a AAW wiring kit installed so I've got the correct wire to the distributor.
About every 2 or 3 thousand miles I loose fire at the distributor. I've replaced the module each time, I've gone through 4 or 5, and the truck'll start right up and run fine till it decides not to start again. My question is is there something in the distributor that can be causing the modules to go bad? I replaced the coil with one off the shelf, didn't help. I just ordered a new DUI distributor from Summit out of frustration. Any and all help or advice is welcomed.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
05-18-2020, 04:43 PM | #2 |
Re: HEI distributor problems
Possible grounding wire underneath the 2 screw plastic coil cap is missing
05-18-2020, 05:29 PM | #3 |
Possible improper voltage during startup, this can slowly kill an HEI module. Good idea to double check it so you can cross it off your list if it checks out.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
05-19-2020, 10:38 AM | #4 |
Msgt USAF Ret
Do you still have an external voltage regulator charging system? The modules in the HEI distributor do not like voltage spikes and the external regulators have been suspected to be the cause of module failures because they do not do as good a job of keeping the voltage in the circuit at a constant value.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-19-2020, 11:26 AM | #5 |
Just got in from the shop and here's what I've found.
KWMech, yes ground wire at the coil is attached. SouthCity, voltage at the distributor is 12V with key on, 9V when cranking engine, and 13.8-9V running. VetteVet, I have a one wire alt. 100Amp Powermaster. One thing I noticed when I tested voltage while running was the voltage would drop to 4 or 2V just for a millisecond and the be right back to 13.8. I checked the running voltage at both the distributor plug and at the fuse panel bulk head connector at the firewall. Wiring is new AAWclassic update for HEI and one wire alt.
05-19-2020, 12:58 PM | #6 |
Ground wire INSIDE the coil
05-19-2020, 01:15 PM | #7 |
Yes I pulled the plastic cap off the coil and the ground wire is attached to one of the screws that hold the coil in.
05-19-2020, 02:54 PM | #8 |
Engine block to frame ground, frame to body, battery to body. Check them all. I've run HEIs for years with original alternator without any problems. My 68 still has the original alternator and regulator on it
05-19-2020, 04:28 PM | #9 | |
I'm using the starter positive post to pick up power to the cab instead of running a separate wire from a junction block beside of the battery as was factory. I don't think that would cause the problem. Sure has got me stumped, I'm leaning to a glitch in the distributor itself. As far as the voltage dropping to 9V at the distributor when cranking is that because of starter drain?
05-19-2020, 07:58 PM | #10 |
I'm surprised nobody has asked what you are using under the module to goo it down, if you're using heat sink compound.
05-19-2020, 09:12 PM | #11 |
2nd on the heat sink question.
What is your plug gap? Normal HEI is .045. Early ones had special plugs and .060 but I think they went to .045 as a more reliable gap. |
05-19-2020, 10:41 PM | #12 | |
Plugs are gaped at .045
05-19-2020, 11:12 PM | #13 |
Well if your new DUI distributor starts getting failed modules, I would next suspect the alternator and aim to put a 3 wire internally regulated one on the truck, with the sense wire connected at a junction away from the alternator (not just connected on the big post of the alternator with a few inches of wire). I have also seen really weird things happen in vehicles due to a battery that is failing but still cranks and works in the vehicle for a couple more years. I have not seen distributor module failure due to that, but it would not surprise me. I do wonder about your short duration voltage drops to 2 or 4 volts, and about the dropping to 9v during cranking. Do you have electric fans on the radiator?
05-20-2020, 08:21 AM | #14 | |
Thanks to all you guys who have given insight to my predicament. If I get a concrete answer I'll let every one know.
05-20-2020, 05:49 PM | #15 |
sub'd
05-20-2020, 06:36 PM | #16 |
Check the Pickup coil in the bottom of the distributor for bad wires, signs of heat and shorting.
1957 3100 1950 5 window |
05-21-2020, 07:07 PM | #17 |
Got my new DUI distributor today but won't be able to get it installed till the first of the week. Our new pergola kit for the patio arrived today also so you guys probably know which one I'll be working on for the next couple of days. LOL
05-21-2020, 07:08 PM | #18 |
I'll check the old distributor when I pull it.
05-21-2020, 09:15 PM | #19 |
05-22-2020, 12:17 PM | #20 |
Super Lube silicone heat sink compound. Bought it at Auto Zone
05-25-2020, 04:28 PM | #21 |
Do you have anything connected to the solenoid "R" terminal?
'67 GMC 2500, 292, 4spd, AC |
05-25-2020, 07:06 PM | #22 |
No my starter doesn't have a R terminal.
I talked to AAW about the voltage drop to 9 V when cranking and they said that's normal. I put a new battery in Fri and when running the voltage at the distributor is a constant 13.8.
05-25-2020, 08:27 PM | #23 |
So there has been no changes to the charging system during all these failures?
If so have you checked the alternator output for AC voltage? If the diode bank in the alternator is failing AC voltage could be spiking the modules and causing the failures. This one of those times an oscilloscope is handy.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-26-2020, 02:23 PM | #24 |
>>Super Lube silicone heat sink compound. Bought it at Auto Zone<<
I looked at the Autozone web page to see what Super Lube product you are using. I couldn't find it there, but I assume the image below is the product you are talking about. A Dielectric is the exact opposite of a heat sink compound so I don't think Super Lube knows what they are selling. A Dielectric is an insulator. I would not use that product. You need a thermal grease, thermal paste, thermal compound, CPU grease, heat paste, heat sink paste, or thermal interface material, but not one that says dielectric. The last couple of HEI modules I have bought, came with a small individual application packet. Those packets are unlabeled, but I used them. I assume Accel knows what they are providing. I still have a small tube from Radio Shack, but next time I'll probably get a CPU grease from some place like Best Buy. Don't be confused by a product that can handle high heat. You need a product that can transfer heat. >> I noticed when I tested voltage while running was the voltage would drop to 4 or 2V just for a millisecond and the be right back to 13.8. I checked the running voltage at both the distributor plug and at the fuse panel bulk head connector at the firewall.<< Do you get that 4V at the Alt Bat terminal? The 13.8 is at idle? What is the Alt bat terminal voltage at idle and with the engine held at 15-2k rpm for a full minute? I'd loose that 1-wire Alt.
05-26-2020, 02:59 PM | #25 | |
