Old 05-17-2020, 10:01 PM   #226
Camaroguy
Camaroguy's Avatar
Re: Son's 68 c10 Short Bed
Originally Posted by KevinK7 View Post
That truck is looking great, ...and I love that color too Awsome work
Thank you. It will hopefully start coming together quick. The boy is getting excited for sure.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
Old 05-19-2020, 12:19 PM   #227
Camaroguy
Camaroguy's Avatar
I ordered a "smoothie" bumper for the rear of the truck a couple months ago. It finally came in the other day and looks real nice. This is the match to the front bumper I had previously purchased a few years ago.
Old 05-19-2020, 03:45 PM   #228
SCOTI
SCOTI's Avatar
Can you get/post a pic of the inside (back-side)?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-19-2020, 04:00 PM   #229
Camaroguy
Camaroguy's Avatar
I have it boxed up and put away for now. I have used these in the past though and there is a tab welded on the inside of the bumper that your bolt slips into. The shoulder of the bolt holds it in place and it is then bolted to the factory brackets. Basically it is exactly the same as an original bumper but instead of the bolts shouldering through the bumper they rest on the tab.
Hope that makes sense - I will see about getting a picture this evening.
Old 05-19-2020, 04:43 PM   #230
SCOTI
SCOTI's Avatar
Thanks. That's what I wondered. I did mine back in the early 90's before stuff like this was available. I used hardware bolted to the factory brackets w/a plate sandwiched between them on the inside of the bumper. Installed the bumper, tacked/welded the plates to the back of the bumper & the hardware to the plates. Then cut the heads off the hardware & welded the holes up from the front.
In retrospect, I should have just welded regular hardware to the plates on the inside vs the bumper face & the plate. The plates helped spread any impact load (which worked). But, since the bolt was still welded in the OE holes as well, they puckered when it was involved in a fender-bender. You know what they say about hind-sight....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-19-2020, 06:46 PM   #231
Camaroguy
Camaroguy's Avatar
That makes sense. I had a dog run out in front of me while I was driving this truck a few years ago. I couldn't even react before I hit it. That stinking thing wadded my front bumper up like I had hit a brick wall. The worst part was both of my kids were with me. I pulled over and they were crying, I was fighting tears too, but it was for a totally different reason.
Old 05-19-2020, 07:44 PM   #232
Camaroguy
Camaroguy's Avatar
Here are the pics...
Old 05-19-2020, 08:09 PM   #233
SCOTI
SCOTI's Avatar
Awesome & appreciated! What's your opinion of the bumper quality?
I know when I did my 74 & was looking for new bumpers the aftermarket stuff was crap (you could easily twist the bumper end-to-end). It took a while but I found OE units. I had OE units on my '89 dually until it got tagged in a p-lot. I was having a hard time finding another rear so I tried one of the LMC Premium units (along w/one of their Blazer gate panels). The aftermarket unit for that was as nice as my original OE unit. Weighed about the same & zero twist/flex end-to-end.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-19-2020, 10:17 PM   #234
Camaroguy
Camaroguy's Avatar
This is the 4th of this style I have bought and have no complaints. Jegs offers the best price I’ve found.
Old 05-23-2020, 09:15 PM   #235
Camaroguy
Camaroguy's Avatar
Yesterday, we got the inside of the bed done. Came out pretty slick. Today, we finish sanded the bed sides and they will get sprayed on Tuesday.
Old 05-25-2020, 12:21 AM   #236
cornerstone
cornerstone's Avatar
Looks as good as a brand new one piece floor. Do you still think you would have been money ahead if you bought a new floor?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-25-2020, 09:28 AM   #237
Camaroguy
Camaroguy's Avatar
Thank you. I definitely would have been better off just buying a whole floor. This floor was all new, just came in two sections. Honestly though, the floor has been all done by my son. He cut it out, welded it back together, ground it down, filled it, and did 3-4 rounds of sanding it. It came out nice and it really is the one part that has been all him. That in and of itself, is probably worth it.
Old 05-25-2020, 09:43 AM   #238
cornerstone
I totally forgot about that aspect... excellent point and so true.
Brian
Old 05-25-2020, 10:33 AM   #239
KevinK7
KevinK7's Avatar
... Honestly though, the floor has been all done by my son. He cut it out, welded it back together, ground it down, filled it, and did 3-4 rounds of sanding it.
There is so much to be said for things you do and learn first hand. Along with the sense of accomplishment, you truly appreciate and respect the things you have built.
No doubt he will treasure this truck for many many years to come, due to lessons learned, but even more importantly........time spent with Dad
That truck is truly something to be proud of on many fronts, for both you and your son
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 05-25-2020, 10:59 AM   #240
Camaroguy
Camaroguy's Avatar
Thank you for saying that. All true words, for sure. Too many people in today's world have no concept of problem solving - in any aspect. One thing you learn when working on this stuff, is how to do just that. Solve the problem. Hopefully it translates to other things.
One of the biggest parts of this, for me, is him understanding and grasping his "Papa's" legacy.
Old 05-25-2020, 12:45 PM   #241
SCOTI
SCOTI's Avatar
Props to you for recognizing that need & doing something about it. Too many people these days don't do that either....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2020, 03:12 PM   #242
Camaroguy
Camaroguy's Avatar
Yes sir, we're both blessed for sure.
Old 05-26-2020, 10:06 AM   #243
MDPotter
MDPotter's Avatar
That is a slick bed floor, your son did a great job on it.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-26-2020, 11:09 AM   #244
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Wow! From the old bed liner to this. A lot of work that he can be proud of for sure.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-26-2020, 12:40 PM   #245
Camaroguy
Camaroguy's Avatar
Thank you both. They are painting the outside of the bed today while I'm stuck at work. Hoping I will get some pics at some point.
Old 05-26-2020, 11:04 PM   #246
Camaroguy
Camaroguy's Avatar
I’ll get some better pictures when I can. From what I’m told, it came out great and is really straight. Pretty happy about that, because it was pretty rough.
Old 05-26-2020, 11:41 PM   #247
SCOTI
SCOTI's Avatar
Looks good from here. 🤓👌
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-27-2020, 11:42 AM   #248
Camaroguy
Camaroguy's Avatar
I just ran down to the shop and snapped a few pics. It still needs to be color sanded but looks pretty good.
Old 05-27-2020, 11:43 AM   #249
Camaroguy
Camaroguy's Avatar
Continued:
Old 05-27-2020, 11:52 AM   #250
Camaroguy
Camaroguy's Avatar
One more:
