Elecrtical?
Well first the good. Started my truck for the first time and success it runs great. The bad, electrical. Here is my dilemma. I have the American Autowire harness I installed. I am running the dolphin/shark manual gauges. When I turn the truck on my gauges are on. I have tried everything I can think of but after 3 hours and same issue I took a break. The back of the gauge with volts/fuel/temp/oil there is a harness with a black, yellow, red, white, blue, green. I know the green is oil, blue is fuel, white is temp, black is ground. The red is + and yellow is + (light switch). This is what manual says. So if this is right I hook the red to 12v fused source and the yellow to???
My speedo gauge just has the 2 wires for the bulbs, red/black. When I hook the grey wire from American Autowire harness that says dash light clearly on the wire to the red wires, and the black to ground, the lights stay on. As I am not a wiring guru, I have followed all instructions but this one has me perplexed. Any thoughts and ideas would be appreciated.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end. ![]() http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670 |
![]() ![]() Join Date: May 2015
Re: Elecrtical?
I would think the yellow wire would be hooked to the AA gray wire, and the red would be a switch on 12v
and the red from the speedometer would need tied into the yellow without instruction sheet I'm just guessing can you check the AA gray wire to see if you can turn the power on/off with the switch?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-22-2020 at 10:34 PM. |
Re: Elecrtical?
Sounds like you have the gauge lights connected to the wrong side of your headlight switch. Your gauge lights (yellow wire) need to be connected to a switched 12v source - IOW the output side of your headlight switch. I think American Autowire uses standard GM color coding, so the gauge lights (yellow) should connect to the brown wire out of the headlight switch (may be labeled something like Dash Lights, Park, Tail, etc). Use a test light to confirm.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 05-22-2020 at 11:43 PM. |
#4 | |
Re: Elecrtical?
#5 | |
Re: Elecrtical?
Re: Elecrtical?
I'm not sure which kit you have from AA , but I was looking at their schematics, and it does show the gray wire for the dash lights...check that to see if it will turn 12v on/off with the switch
well ,I just saw where you said it wont...so scratch that... like miracle says,,,check your switch wiring...are you using the AA switch?
Re: Elecrtical?
Here are some pics of switch and diagrams. The brown wires on switch are for tail and park light feed.
Re: Elecrtical?
mongocanfly. Tried the grey wires that are labeled dash light. When I connect the red wire or yellow wire to them the lights come on. Switch will not turn them off. In the pics above the switch and switch plug was set and included in the kit so I just plugged them in.
#9 | |
Re: Elecrtical?
Re: Elecrtical?
that shows the dark green wire for the instrument lamp
somewhere its switching from green to gray... does it leave the switch green and then change to gray at the connector?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-23-2020 at 01:38 AM. |
Re: Elecrtical?
Did you use the Part #: 500467 classic update kit or the Part #: 30905 complete wiring set (original replacement) kit?
Also do you have the original headlight switch or an aftermarket switch?
Re: Elecrtical?
The green goes from the switch to the fuse box. No green out of fuse box. I am thinking that must be the relay and grey wires coming out of fuse box. I have 2 of them.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end. ![]() http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670 Last edited by J48chevy; 05-23-2020 at 11:22 AM. |
Re: Elecrtical?
Kit 500467 and the switch came in the kit.
Re: Elecrtical?
Diagram for the switch. I verified every wire is correct. It almost seems like the grey wires coming out of the fuse box labeled dash lights have constant low power. Light are on low. Then pull switch and they are bright. Confusing.
#15 |
Re: Elecrtical?
Hmmm..sounds like you got everything right...may need a call to AA next week..I've been looking thru my installation instructions...and i cant see anything you've done that stands out as wrong...
#16 |
Re: Elecrtical?
there should be a pink wire in your harness marked gauge feed that is a 12volt ignition source that should provide ignition 12v to your gauges so the dash does not come on until you start the truck. the grey wire is gauge lights that comes from your headlight switch.
#17 |
Re: Elecrtical?
This ain't that complicated. Any of those wires emanating from the headlight switch that are cold when the switch is off and hot when the switch is pulled could be spliced into the gauge lights. A test light will tell you which, but according to my GM wiring diagram for Dolphin Gauges either of the brown wires will work.
1951 Chevy Panel Truck |
#18 |
Re: Elecrtical?
The brown wires from switch to fuse box are for front and rear park lights. The green wire from the switch to fuse box them have 3 grey from fuse box for dash lights. I had it working fine earlier with no lights staying on. Got home and wanted to check again and yep they are back on at low voltage. I did notice that the hazard round silver fuse is getting warm. This is the 2 brown wires from the switch to fuse box. Any idea why that would be hot and could that be the issue?
#19 |
Re: Elecrtical?
if you hooked into the park light circuit (brown wire),then you would have no ability to dim the dash lights.but the lights should work when you turned on/off the park lights..theres some issue there that's causing a problem..
#20 |
Re: Elecrtical?
Thanks yeah 2 days of messing with this drives me crazy. You would think it was a basic easy install.
#21 |
Re: Elecrtical?
I'm wondering if your light switch has a issue
#22 |
Re: Elecrtical?
I was thinking the same thing. Might just order one and try.
#23 |
Re: Elecrtical?
that round silver thing you called a fuse is not a fuse its the flasher for the turn signals/4ways. I think maybe you are confusing the power feed for the gauges with the dash light circuit. according to the above pictures you have a factory fit wiring harness, that means your dash/gauge lights should be fed from the green wire coming from your headlight switch. I would use the tan wire marked CB to provide 12v to your gauges for their power, gauge power and gauge light power are 2 separate functions. with gauge light power hooked to green from the headlight switch you should have dimming and should switch off with headlights.
#24 |
Re: Elecrtical?
Well I found what wire is causing issue but no idea how to fix. Here is what I discovered. Bad switch or why is rear brown wire causing this?
When I have everything connected correctly the dash lights stay on low power, tail lights off and brake lights work. Pull light switch out and can dim and adjust lights but taillights are bright and no break lights. So I checked all wires on switch. Found that if I disconnect the rear brown wire then dash lights do not stay on but tail lights are on and still have brake lights. When I pull switch out dash lights work and can adjust and dim. It seems this one brown wire is causing the issue? 2 brown wires on switch. One to front and one goes to rear. Now I don’t have headlights connected yet but wouldn’t think that would cause issue? Wires are just run to the front of truck right now.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end. ![]() http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670 Last edited by J48chevy; 05-24-2020 at 01:53 PM. |
#25 | |
Re: Elecrtical?
