05-21-2020, 07:58 PM | #1 |
Moderator
Harbor Freight Jack Stand Recall
https://images.harborfreight.com/hft...1196_61197.pdf
Urgent recall on all HF Jack Stands id numbers 56371 or 61196 or 61197 Stop using them and return to store for store credit....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-21-2020, 08:01 PM | #2 |
Re: Harbor Freight Jack Stand Recall
This is why I like the old school type. Place a rod thru the holes. No chance it will get jarred and drop.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-21-2020, 08:39 PM | #3 |
No offense to anyone in particular, but.......
As they say if the shoe fits HARBOR FRIGHT! |
05-21-2020, 10:23 PM | #4 |
Thanks for sharing. Can't say I'm unhappy with the Strongway, I bought four sets. That said, unbelievable anyone would produce junk jack stands, perhaps they don't know what they're for.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-22-2020, 10:46 AM | #5 |
Thanks for posting! I have my rear axle out and my truck is sitting on these jack stands right now. I have been working under the truck for the past month and felt sketched out the entire time. I put the wheels and a second set of stands under there just to be safe. Just another reason to avoid HF.
The shop that is installing my locker is taking forever. Pissed off at HF, pissed off my axle is not finished. Most of all pissed off at myself for being cheap and shopping at HF. Jack stands and tarps are the only thing I have ever purchased from HF. Note to self avoid HF Chinesium. Guess I'm going to have a lifetime supply of tarps because I certainly won't be buying another set of stands with the refund.
Made in America by Americans |
05-22-2020, 02:50 PM | #6 |
I started out with nothing - and I still have most of it |
05-22-2020, 04:52 PM | #7 |
Thanks for posting. Some folks like to bash HF but if you buy correctly they are good value. I bet their jack stands come from some of the same Asian vendors as those of other more upscale stores. I choose wisely what I buy at HF. I've had good luck there with:
- Consumables - cut off wheels, nitrile gloves - Their older line of small equipment engines, which were Honda knock-offs for 1/3 the price which I still have one on a roto-tiller, starts every time - Air tools, hoses and fittings - same Asian vendor as Campbell Hausfield - I have a set of combination wrenches I bought there 8 years ago that are every bit as good as my Craftsman wrenches - Their cheap spray guns, for primer and frame painting - use them once and toss them! No need to clean them! I stay away from their power tools and basically anything electric. YMMV as they say but it has its place. |
05-22-2020, 05:15 PM | #8 |
Who Changed This?
I've also heard "Hazard Fraught".
05-22-2020, 05:45 PM | #9 |
Definitely like their nitrile gloves, and a cheap oscillating tool to get all my floors done... ironically, a good oscillating blade was nearly as much as the tool!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-23-2020, 01:05 AM | #10 |
Thanks for posting. Mine are 8 years old and not on the recall. I'm not a big fan of Harbor Freight but they are only 4 blocks away and stay open till 9:00 pm. Which is why I have a set of their jack stands.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-26-2020, 08:14 AM | #11 |
Thanks for the post. You in Churvull huh? I am in Vale down near Mitchems Kitchen.
1972 Custom 10 Deluxe- original paint, interior- 72k miles http://www.cardomain.com/ride/2466316 Cheap, Fast or Good. Pick any two. 1990 Eagle Talon AWD 1991.5 W250 CTD 1992 Cushman Truckster- Haulster |
05-26-2020, 10:05 AM | #12 | |
One of the best tools in my garage is a Daytona floor jack. Props HF drill bits for wood too. Sure they snap easy if you do it wrong, but they out-drill common bits that are far more expensive.
05-26-2020, 06:08 PM | #13 | |
Moderator
05-26-2020, 10:26 PM | #14 |
I use harbor freight for simple, chunk-o-metal stuff that nobody could POSSIBLY screw up, you know, like jack stands...
I have a slew of 3 and 12 ton (a bit of overkill, but used for tractors) that look just like the recall ones, but have a different part numbers. Hmmm... Last thing I don't want not trust is my jackstands. What's next, my dog? |
05-27-2020, 07:01 AM | #15 |
That's not old school. Plenty of old school cog-type jack stands out there with no pin. That's a newer idea on the cog type. The older jack stands I've seen that use pins are the cheapest stamped steel with the pin being the only thing holding the extension up. The pin in the later cog-type is an extra safety measure. My cog-type have no pins and I never worry. When there is weight on them the handle can not lift and release. It's a great age old design that works as well today as it has all along.
05-27-2020, 08:08 AM | #16 | ||
especially in third world countries where respect for even their own lives is relatively low by comparison.. relying on any standard of quality these days is a gamble.. design with less chances of error is a safer bet.. lack of visibility inside a ratchet system garners less assurance than a visible pin positively engaged through a support structure.. comparing hein warner, lincoln, otc, etc., especially vintage production to modern harbor freight is imprudent with regards to quality.. ratchet type stands are not categorically unsafe, but for pete's sake at least insist on some commitment of quality.. to each their own, but when making recommendations, please remember they are often called "safety" stands for a reason I posted this in one of the other threads, I think it's worth reading so I'll leave it here too.. I'm passionate about this as these are common tools in my trade and I supervise others that use them daily.. and while they may not be listed in these articles, Gray manufacturing makes some of the best stands IN the United States Quote:
05-27-2020, 08:16 AM | #17 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
05-28-2020, 12:44 AM | #18 | |
05-28-2020, 12:34 PM | #19 | |
05-28-2020, 01:02 PM | #20 | |
05-28-2020, 01:49 PM | #21 | |
One of the First
My two sons are starting to recognize the quality of tools that they have compared to mine. I think they are starting to mark'em as to who gets what when I crook. American, Japan and German steel is the best. India and Romania is OK, coming in last is Taiwan and dead last is Chinese. Harbor Freight and Northern Tool is so darn coinvent to get anything. To bad Sears and craftsman went upside down.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
05-30-2020, 09:32 AM | #22 | |
06-12-2020, 06:22 PM | #23 |
06-13-2020, 07:04 AM | #24 |
06-13-2020, 07:11 AM | #25 |
The labels on my old Blackawks are aluminum, much stronger than a sticker
That is just ridiculous. Great to know since HF put out flawed and dangerous jack stands they had to recall, the next ones they put extra effort into assuring the quality. At least this problem is less likely to cause a sudden drop. And if you got under a vehicle with a jack stand without seeing that, shame on you I think I have it all figured out now. Manufacturing went over to China but quality control stayed in America. Welcome to the largest quality control team on the planet!
