Old 05-30-2020, 01:03 AM   #6251
Gregski
Gregski's Avatar
Re: Restoring Rusty
now as far as my Left (aka driver side) turn signal problem, technically it ain't a turn signal problem, the turn signals work fine, all of them
the problem is the parking light or what ever you want to call it, the left aka driver orange parking light in the left fender does NOT come on
here are the facts:
1. there is a light brown wire that runs from the black square bulk head connector on the firewall to both the left and the right side parking lights
2a. a light blue wire runs from the same bulk head connector to the left (driver) side orange parking light in the fender
2a. a dark blue wire runs from the same bulk head connector to the right (passanger) side orange parking light in the fender
TROUBLESHOOTING
teach me something because my testing shows I am a total ignoramous
I thought the light blue and the dark blue wires were supposed to be positive and when touched to ground with a test light the test light should illuminate, but that is not what happens in my case, the opposite is true, the light comes on when with an alligator clip on the light or dark blue wires when I touch the pointy end of the test light to the positive terminal on the battery, but whatever I think the blue wires are for the turn signals and those seem to work
now the brown wire I assume is the common wire for the parking lights both left and right, so I don't get why I get no signal / power in it at the left fender, I think I need to unwrap it all all the way back to the bulk head and examine every inch for splice-atalogy problems
Gregski is offline   Reply With Quote
Old 05-30-2020, 03:57 PM   #6252
LT7A
Re: Restoring Rusty
It's not a good sign when the task does not even receive a fun level rating. Good luck man.
LT7A is online now   Reply With Quote
Old 05-30-2020, 04:03 PM   #6253
Gregski
Gregski's Avatar
Re: Restoring Rusty
LOL, yup, this task is yet to be rated, your comment on the other hand ...
Comment Level: Expert
Old 05-31-2020, 12:30 PM   #6254
LT7A
Re: Restoring Rusty
Hahaha
Old 06-01-2020, 07:39 AM   #6255
texxxan
texxxan's Avatar
Re: Restoring Rusty
I'm glad to see that Rusty is getting some love.
texxxan is offline   Reply With Quote
Old 06-01-2020, 03:44 PM   #6256
Gregski
Gregski's Avatar
Re: Restoring Rusty
yup, me too, but he's been a little shiet lately
Old 06-01-2020, 03:45 PM   #6257
Gregski
Gregski's Avatar
Re: Restoring Rusty
EUREKA !!! I finally figured out my left side marker (parking light) problem. FOUR YEARS later.
Old 06-01-2020, 04:02 PM   #6258
texxxan
texxxan's Avatar
Re: Restoring Rusty
Do tell...
Old 06-01-2020, 04:20 PM   #6259
Gregski
Gregski's Avatar
Re: Restoring Rusty
Do tell...
ha ha, short answer: bad (yet fully functional) sister parking light bulb aka the one below the headlight above the bumper!?
full report @ 11:00
Old 06-01-2020, 08:49 PM   #6260
Gregski
Gregski's Avatar
Re: Restoring Rusty
so basically in order to fix this Parking Light
Old 06-01-2020, 08:51 PM   #6261
Gregski
Gregski's Avatar
Re: Restoring Rusty
... we had to replace a perfectly good in working order light bulb in this Parking Light
We will just file this repair in our "I hit myself in the head with a hammer cause it feels good when I stop" folder and collectively move on.
Old 06-01-2020, 08:57 PM   #6262
Gregski
Gregski's Avatar
Re: Restoring Rusty
Wait, what? Inquiring minds want to know how I fingered it out?
Alright, after all you are under quarantine, or as I like to call it a captive audience, ha ha
so on a serious note I want to share what I went through because it can actually help somebody out and maybe knock off a year or two off the time it takes to fix this, ha ha
Here's how I went about it. I wanted to figure how these lights worked and not just hack at it until it worked.
The first thing you need to do is figure out how a component works, in this case what each wire does. This was simple enough as the pig tail in question only had two pig tails, a light blue wire and a brown wire.
Now here's a Top Tip: when trying to figure out how something works, doing so when it is broken is definitely not the time to do it. Lucky for us we had another turn signal / marker just like this one on the other side in working order, so we employed our Stare and Compare methodology.
this allowed us to quickly pick up on the fact that although each light had a different color blue wire (drive side light blue, passenger side dark blue) they each shared the same brown wire, this allowed us to Divide and Conquer even further.
Old 06-01-2020, 09:03 PM   #6263
Gregski
Gregski's Avatar
Re: Restoring Rusty
since the turn signals were working we focused on the brown wire, to simplicate things even further and eliminate the fuse panel and the light switch, I removed the bulk head connector off the firewall and alligator cliped a power lead from the battery positive terminal directly to the brown wire pin on the back side of the bulkhead connector - and watched three of the four marker lights illuminate
Old 06-01-2020, 09:09 PM   #6264
Gregski
Gregski's Avatar
Re: Restoring Rusty
after poking and probing with a test light and things not making sense I decided to yank the front marker light (the one below the headlight) and stare at it
this one made sense, in addition to the brown wire which we know sends the parking light signal, and the light blue wire which is the left turn signal signal (ha ha) it had a third wire, unlike the side marker light, it had a black wire which was the GROUND! now that makes sense color wires send the +++++ pluseses and the GROUND carries the ----- minuses (I know that's not how electricity actually flows, so please don't call the Electrode Police on me just yet I is just explaining things)
so how the hewk does our little guy in the fender get it's ground? he don't have a metal housing so it cant be contact with the sheet metal
Old 06-01-2020, 09:23 PM   #6265
Gregski
Gregski's Avatar
Re: Restoring Rusty
why it has to be getting it's ground through the light blue wire somehow, there is no other choice
so I poked at it some more with my test light and nothing, so once again I went to the working side and sure enough with the test light alligator clip connected to the battery positive terminal when I poked at the dark blue wire connector inside the socket it acted as a ground and the test light lit up
so back I went to the bad side and hooked up a long black wire lead from the battery negative terminal to an exposed section of the light blue wire at a Y junction as a temporary bypass and sure enough the side marker parking light came on - SAY WHAT?
I know right it don't make no sense, but now we knew how to make it work so lets press on
Old 06-01-2020, 09:30 PM   #6266
Gregski
Gregski's Avatar
Re: Restoring Rusty
so here's what we knew at this point
1. both side and front left marker lights need a ground to function
2. the front market light has a black ground wire the side marker light does not
so how do we send a ground signal from the front market light with the ground wire to the side marker light?
answer: via the stinkin' light bulb
somehow in some way the light bulb takes the ground signal from the front marker light and shares it with the side marker light via the light blue wire (I honestly still don't understand this magic, but I accept it)
I also do not comprehend why a good working light bulb was insufficient to send the ground signal, but a different one of the same model number was
I even cleaned it thinking it was dirty contacts and no dice, when I moved the bulb from the working side to the non working side it would work, when I went the other way it would not, luckily I found another working bulb in my stash
pic of a bulb that would not work though it matched the working bulb exactly, this is the one I cleaned the contacts on after taking the pic
Old 06-02-2020, 08:38 AM   #6267
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
Gee.... I wonder why it took you 4 years to figure out. The solution was clear as mud.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 06-02-2020, 09:22 AM   #6268
moregrip
moregrip's Avatar
Re: Restoring Rusty
Impressive, nice work; I'll definitely try and hold on to this gem in my memory bank!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 06-02-2020, 10:55 AM   #6269
Wgesnerjr
Wgesnerjr's Avatar
Re: Restoring Rusty
If I remember correctly, the side marker and the front signal flash in an alternating pattern, right?
If so, I would think the side marker gets its ground from the front signal bulb when it is NOT activated. Therefore is lit when parking lights/headlights are on giving power to the side marker and ground thru the Front signal bulb.
When front signal is activated, the ground goes to the front signal bulb to light it and stops at the side marker. Therefore alternating the flash. Side, Front, Side Front, etc.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 06-02-2020, 11:28 AM   #6270
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Wgesnerjr View Post
If I remember correctly, the side marker and the front signal flash in an alternating pattern, right?.
Interesting, I just went out and tested it on my '74 and nope, they dingle at the same time. The light blue wire simply has a Y splice and one end goes to the side marker and the other to the front marker. Same deal on the other side but its a dark blue wire.
Old 06-02-2020, 01:22 PM   #6271
truckin 79
Re: Restoring Rusty
I think the ground for lights are right at radiator support or was that the Trans Am. I am pretty sure the grounds are right under the where the fender attaches.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 06-02-2020, 01:42 PM   #6272
Gregski
Gregski's Avatar
Re: Restoring Rusty
Correct but those grounds go to the front marker lights, there are no black ground wires going to the side marker lights.
Old 06-03-2020, 02:10 PM   #6273
Wgesnerjr
Wgesnerjr's Avatar
Re: Restoring Rusty
So I am "working" from home today and looked at my 85. They do flash together. I don't remember where I saw the alternating thing.
I also tested the turn-signal flasher has 2 prongs and it has 12 volts power on one side and, when activated, will flash 12 volts power to the other side. seems like there would have to be a full time ground somewhere.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 06-03-2020, 02:56 PM   #6274
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
The factory wiring makes the side markers alternate with the front turns.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-03-2020, 03:26 PM   #6275
Gregski
Gregski's Avatar
Re: Restoring Rusty
thanks, wish you had some squares to go out and test it for yourself like Jay and I did, question for you: are the front marker lights wired to both the turn signal switch (via the light and dark blue wires) and the headlight switch (via the brown wire) or just one or the other?
