![]() Join Date: Apr 2012
LS Noob Help ..Truck intake ?
Whats up guys, im putting in an L96 Engine and will be running the original truck intake, Im just now removing all parts not going to be used in the swap.
What are all those vacuum and other lines ? What happens to all this stuff ? is there some type of guide as to what is what ? thanks and you all stay safe ![]() |
![]() ![]() Join Date: May 2015
Re: LS Noob Help ..Truck intake ?
which lines in particular?..any pics?...not familiar with the L96 ,but the LS is fairly self contained
The best guide I found, was to buy a one-year subscription to AlldataDIY. This gives you all the factory literature for your donor engine, including wiring harness routing, connector pinouts, troubleshooting procedures, etc.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
There really aren't many vacuum hoses on an LS engine. Being a newer one, even less than the older ones. You probably have a big hose at the back of the intake for power brakes, and a purge solenoid on the top of the intake and that's about it for vacuum lines. The purge solenoid lines can be removed if you are not doing a full emission swap. Just leave the solenoid in there to plug the hole, its normally closed so as long as it doesn't have power going to it. it will be fine The other two, I guess you could call them vacuum hoses, are the PCV hose, which you shouldn't need to do anything with, and the hose from the throttle body to the valve cover which should require no attention either. Then there is the fuel line to the rail, should be pretty self explanatory, and two small coolant hoses from the crossover on the heads to the throttle body, which will need to be hooked to the radiator. You can bypass the throttle body if you want, and if you don't want to have a fitting added to your radiator, you can plumb it back into the water pump.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
here you go guys. i took some pics and circled what im refering to.. Thanks
you don't need to eliminate any of this
heres what I can readily identify... 1. pcv fresh air side--hooks into intake tube in front of throttle 2. pcv system 3. hose going to the purge solenoid 4. map sensor 5. purge solenoid 6. vacuum fitting for brake booster
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-02-2020 at 11:33 PM. |
What if I decided to go with a different intake. Something like the one del uses on his dels3 ?
#8 | |
Anyway, for what you have now, going on the numbers Mongo supplied, 1 and 2 are the PCV hoses, just leave them alone. 3 is the hose going to the purge solenoid, 5, which you can remove. The green cap is the fitting for doing a smoke test on the evap system, again, you wont need it. 4 is the MAP sensor 6 is a plug where you could hook up a power brake booster. To do that you need to remove the plug and put in a nipple to hook the hose to.
thanks Eric...I changed my #ids above to match what you listed to help eliminate confusion..
I used the holley intake stuff on my IH/LS..like Eric said...it aint cheap
thanks guys.. as for not being cheap. what are we talking about here ?
i was going for a overall theme on mine is why I went this direction..probably wouldn't do it again on any other truck because of cost...id just use a LS3 intake
heres what comes from summit 1. intake holley 300-136.........$325.00 2. fuel rails holley 534-218......$163.00 3. assorted fittings..................$50.00+ the rails don't come with any plugs or fittings 4. bosch style ev1 injectors......$ 180.00+... I modified my stock injectors to work with the holley system 5. and youll have to change your harness plugs to match injector plugs if you use some aftermarket injectors....$$+ 6. adaptor plate TB to 4150 pattern....i made mine...would have cost $200+ at machine shop so around $1k +$$$
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-04-2020 at 12:14 AM. |
Nice IH by the way. I own a 1959 B100 and a 1965 C1100 Travelette. Not many dove into the IHs, but I love them.
Customization is what you want it to look like -- not what other people think it should look like |
Thanks evrlet...would love to see some pics if you have any..you can stickem in my IH build thread to keep from jacking chvy s post...
#15 |
Thanks to everyone on this thread! This answered my brake booster question, and clarified where we thought the other lines went.
