#1 | |
![]() Join Date: Aug 2018
Re: TA_C10: Stage 1
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Re: TA_C10: Stage 1
Update - LED Door Lighting
I wanted some modern touches to my truck. Here is one of them. Illumination of the ground when you open the door at night. I bought this kit from LMC for cargo lighting in the bed like 1 year ago. Forgot I ordered the kit and ordered another kit from Amazon for same thing. Well I decided to re-purpose this LMC kit for the door LED's. I basically drilled a screw mounting hole, and also a wire grommet hole for the wire. The pucks will also have 3m double sided tape on them. Testing the kit proved it should do what I wanted. Two pucks for each door. ![]() ![]() ![]() ![]()
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
