06-10-2020, 08:55 PM | #1 |
What Knobs Are These?
So, I am familiar with 'standard' and 'deluxe' knobs in our trucks. My truck is a custom cab and has deluxe knobs for the most part.
What are these on the radio?
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-10-2020, 09:18 PM | #2 |
Re: What Knobs Are These?
I am pretty sure that isn't a factory C10/20 radio. This is the factory Delco radio I am familiar with.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-10-2020, 09:23 PM | #3 |
I think I have the same radio in my '72. The knobs look the same. I have no idea what it's out of. It was in it when I bought it
06-10-2020, 09:27 PM | #4 |
This had a speaker mounted to the roof (including two more holes to patch) and one of the old Realistic FM radio add on units. So, I am guessing somebody at some point added all this fancy stuff.
Also must have had a cb at some point because the mic holder was still screwed to the dash. More holes to patch!
06-10-2020, 10:38 PM | #5 |
06-10-2020, 10:48 PM | #6 |
They are 67/68 Chevelle, Nova, Camaro.
06-11-2020, 07:17 AM | #7 |
Bingo !
I noticed them in the Summit site and planned on using them myself , I just have to check if they fit the rest of the knobs ? Being period correct time wise I believe they will fit our trucks also . They look better than black plastic .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-11-2020, 07:21 AM | #8 |
06-11-2020, 07:50 AM | #9 |
Correct same knobs that were on my 1968 Impala SS 427
06-11-2020, 07:50 AM | #10 |
Well, there you have it. I have learned something already today so now I can quit thinking. I will probably not re-use these so now I need to find someone who has or is building a drive quality chevelle, camaro, or nova.
06-11-2020, 09:01 AM | #11 |
My 67 Bel Air had same knobs....
06-11-2020, 10:56 AM | #12 |
My friend has a 67 c50 with that exact radio and knobs.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
06-11-2020, 10:59 AM | #13 |
So, did the 67-68 C10's have this knob?
06-11-2020, 02:01 PM | #14 |
I can't read writing on the dial. It doesn't say Delco like mine. Can you post what it says? It may help solve the mystery. Does your SPID say it has a radio?
06-11-2020, 02:50 PM | #15 |
OK, so I went out and checked. No radio listed in SPID so perhaps that is the reason for the odd radio and speaker job.
I had to get a flashlight and look but the lettering says All Transistor. I am going to pull the radio and see if there is any more information on it.
06-11-2020, 08:48 PM | #16 |
So the knobs are not plastic. Some sort of chromed cast metal and they look decent with a real quick cleanup. Some polish and they would be presentable.
Wish the PO would have saved the radio delete plate that was probably with the truck at one point. Maybe pull the radio in the next day or so when I get time.
06-11-2020, 11:44 PM | #17 |
Just like today knowledge was valuable back in the day. Since several members have the same radio in their vehicles. I would speculate that folks who knew ordered a radio delete truck and then bought a cheaper radio from GM and installed it themselves to save a few dollars.
06-12-2020, 07:12 AM | #18 |
I think the option would have been way cheaper than buying one, an antenna, and having to install. I think it just swapped out. My truck came with factory radio and this one was in it in '01 when I bought the truck.
I've never touched this radio or done anything about music in this truck for some reason. It looks like the radio fit with no alteration, but I have never confirmed that the dash is uncut. I have assumed a converted factory AM with fit right in. I also have a GM AM/FM from a car that sure looks a lot like the truck radios. It's obviously not to anyone who knows these trucks. It was sure a lot cheaper than a truck AM/FM and all I was is the right look. And 'mostly' what I want is to listen to FM.
06-12-2020, 08:12 AM | #19 |
This also clears up a mystery around my antenna. When I removed the old one it looked like someone drove a spike through the firewall, ran the cable through, and sealed up with some sort of goop. I remember thinking, "That is a terrible job from the factory." Now I know it wasn't factory. Before I run a new antenna it's another item to fix up correctly.
06-12-2020, 09:18 AM | #20 |
These were work trucks back in the 60's. Lots of dealers would order them with out radios and "Dealer install" them if the buyer wanted.
