06-20-2020, 12:26 AM | #101 |
Re: The Vandal. 1957 "Big glass" 3100 restomod.
Beautiful! What brand of paint did you use?
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
06-20-2020, 08:40 AM | #102 |
Coming along nice. It’s going to look killer!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
06-20-2020, 10:41 AM | #103 |
Southern Polyurethanes. (SPI)
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
06-22-2020, 08:31 PM | #104 |
looks nice!! how many coats did you end with and which spray gun?
06-24-2020, 04:32 PM | #105 |
4 coats with Tekna ProLite 1.4 tip. It sprays nothing like epoxy or primer. I moved too fast, causing lots of orange peel on the first couple coats. Slowed down for the last coat, and it filled in the peel. After I get the inside done, I'll test the cut and buff. If that doesn't get out the peel, then I'll sand with 800 and shoot 3 more.
07-23-2020, 01:45 AM | #106 |
07-23-2020, 09:19 AM | #107 |
Looks great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-23-2020, 10:11 AM | #108 |
Wow, great!!!
07-23-2020, 10:17 AM | #109 |
classy!
is that one of those 15" impala wheels?
11-02-2020, 10:06 PM | #110 | |
Thanks, neighbor... I'm also in Eagle.
11-02-2020, 10:06 PM | #111 |
11-03-2020, 09:40 AM | #112 |
I really like your color combo...
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-04-2020, 10:49 AM | #113 |
looks great bud!
11-04-2020, 11:24 AM | #114 |
11-07-2020, 11:29 AM | #115 |
Update on painting. Short story, I switched to black base & clear coat, and re-painted the cab. I can't form an opinion on which is better. Base/clear, or single stage. I think the clear makes the black deeper and darker. Overall, I fought with dirt, dust and lint, and hope it will all cut/buff out. Everything from the cab forward is done, I haven't even unboxed the bed and fenders yet. Meanwhile, I will focus on getting it running before cut/buff and put the fenders on.
Radiator, and transmission plumbed. Serpentine belt installed.
11-07-2020, 04:52 PM | #116 |
Looks nice!!
11-08-2020, 12:25 AM | #117 |
Sweet...Jim
01-06-2021, 05:01 PM | #118 |
Any updates? quick question. which did you find easier to spray , single stage? bc/cc? Iam guessin you went with spi clear, which one to you go with and and was it to buff. still torn over hear on ss or bc/cc
01-09-2021, 05:40 PM | #119 |
Slammed57, No updates. I had a little time before christmas to work on this mess.
I used SPI black base, and SPI universal clear. For the long story version... When I did the single stage, there were some areas of heavy orange peel that removed too much material to sand out. I broke through to the primer. I called SPI and had a long conversation. He said I would have to respray vs. spotting in and blending the single stage. The rough areas were due to me (f'n novice) not getting the gun close enough. After a long conversation , his opinion is that base/clear is a better choice for novices. Therefore, I decided to start over with base/clear. Some of the reasons being that you can repair and denib the base coat until it is perfect. Black base is blacker due to the higher pigment load. Neither way is easier. I could not keep the dust and trash out of any coat. Therefore, there are a lot of imperfections. My overall opinion, universal clear was easier to spray than single stage. To get enough coverage to sand it out, I hammered on 5 coats. To my eye, base clear is blacker and has more depth with a 'wet' look, which I prefer. So far I have only cut and buff the cowl panel. Time consuming, but buffed easy. 1000-1500-2000-2500, trizact 3000-8000, sonax cutmax, sonax polish. It is a lot of steps! Either way, it is a LOT of work, and I'm considering sending the bed out for paint instead of doing it myself. To get back to SS vs. base/clear, IF I ever do it again, I will still do base/clear. I like the way it looks better than single stage. Hope this helps...
01-09-2021, 07:28 PM | #120 |
Navy Radioman Veteran
Just finished going through the thread... nice work!
I sent mine to the shop in 2013 where they got all the body and chassis work done and it's been in storage until last fall. Our end products are going to close to twins... Hoping to get it on the road in the spring. Ken
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
01-10-2021, 05:31 PM | #121 |
I appreciate it, just keep at it , little by little. Dont you just love electrical? Iam being sarcastic of course.
01-18-2021, 01:19 AM | #122 |
Slammed, I will admit this project broke my spirit for building cars. I have lost all motivation. I'm at the point that I just want this thing out of my garage, and out of my life. Once the engine fires and lets some smoke out of the tires, I may change my mind. Hopefully soon!
01-18-2021, 09:11 AM | #123 | |
Enjoy the journey!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
01-18-2021, 11:15 AM | #124 | |
01-18-2021, 04:06 PM | #125 |
life happens, understand your thoughts, truk took 8 years due to a lot of walking away
paint looks awesome, mirror finish
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
