06-28-2020, 03:16 PM | #1 |
Re: T-5 swap time
Thanks I'm not seeing any rivets..its a 60 so the frame and it looks to be welded on. I don't have a lift to move the motor
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
06-28-2020, 03:25 PM | #2 |
Re: T-5 swap time
06-28-2020, 09:40 PM | #3 |
60-66 Nut
Re: T-5 swap time
Just cut that bellhousing crossmember out of there. You aren't using it so as you have found out, it is in the way. You must already have a transmission crossmember then, so you won't have to build a new one.
06-29-2020, 10:43 AM | #4 |
Re: T-5 swap time
Thanks . The po had some L brackets to support the bellhousing to the
bell mount crossmember. I picked up an original automatic crossmember a while back and will use that instead. ....
06-29-2020, 07:06 PM | #5 |
Re: T-5 swap time
Hey - diefinitely following this - I may want to do this also.
What is the ratio of your rear differential?
1963 C20, small window, long bed 292, 4-speed |
