help i.d. a detroit 2stroke 4 cyl engine size
i found a possible deal on a 4-53 or 4-71 detroit that ran when parked cause it was to out dated for its use anymore .
its in a genset unit and was to complicated for young people to figure out at the place it was used so they got a newer unit that was stupid proof for them to run and just parked this unit . i have no clue what size 4 cyl it is but if i can get it i would like to know what i have to deal with . then if i can get it to run maybe what it would take to stuff it in a project truck . . . but thats much later if it happens .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
New Member
Re: help i.d. a detroit 2stroke 4 cyl engine size
4-71
Nice find.
I always wanted a small Detroit Gen Set, but could never find one locally.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
well then if its a 4-71 then if i get it i got my work cut out for me .
ether way if i get it ....... its on wheels and mobile and has its own fuel tank and rad as it was built for stand alone use . got to find out if i can get it yet . and if so i think the price might just be cheep FREE or a few bucks . ![]()
if i wanted to make it a road use engine what parts would need to be swapped over ?
I've had all the 2 stroke leaktroit fun I can stand already but no idea about these smaller ones..
these guys seem to know the difference tho, and may be a good place for your other questions.. good luck! https://www.dieselenginetrader.com/d...435001/9/3482#
I started out with nothing - and I still have most of it |
#7 | |
![]() Join Date: Feb 2000
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Agree, I was thinking the same thing.
Curious to what truck you have in mind. I'm all for Detroit's and love swaps, but keep in mind that they are surprisingly heavy.
thanks for the help guys .
it is a 2 big center round nob hold down valve cover . also the exhaust is driver side and blower pass side with bell housing in the rear . if it had been a 4-53 maybe a k30 truck but since its a 4-71 then i think a 88 gmc 7000 dump i have would like it more and handle it better . if i wind up getting this unit then i will update this thread as it goes .
Good choices.
Keep us posted on it.
well 2 phone calls today and the 1st got me to the 2nd and the unit is NOT in there system . all i need to do is take a few pics and a pic of the serial tag # and email them to this guy and if its still not found in the system via the serial # then he will give me a paper that says its free and clear and i can have it .
sounds like i need to dig out the pintle hook for the truck ![]() ![]() and the 1st guy remembered the unit from YEARS ago and said its still there ? ? ? ha ha ha ![]()
![]() Join Date: Feb 2016
Definitely a different govenor is in order. You may want to look for a different camshaft too. 471 generators were usually set up to run at a steady1800 rpm. Using it with the generator specifications means you will give up low end torque. A generator is designed to start up and go to working RPM with no load. Then when the generator is put on line the govenor is set up to keep the engine at 1800 +/- 100.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-4 buddy .
still waiting to here back on the unit .
