06-19-2020, 09:45 PM | #1 |
Chime/audible module
I need someone to double check me. I have the attached chimes/audio module and I'm looking to see if this the right part number (22529441) for my truck. I'm not sure where this came from and it works great for headlight chime in key in Ignition chime. But it does not work for seatbelt chime. If anybody can check my part number and make sure it's right for an 85 Chevy pickup I would be grateful. If it's the right part number, I think it might be faulty.
Thank you. Jay
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
06-20-2020, 01:00 PM | #2 |
Re: Chime/audible module
Further development
The chime module bench tested as bad. So that will have to be replaced. Also the seat belt retractor wire tested bad as well. It always thinks the belt is buckled so it will not set off the chime or warning light on the dash. If anyone knows how the retractor signal wite works, please le me know
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project Last edited by Wgesnerjr; 06-20-2020 at 01:11 PM. |
06-20-2020, 05:08 PM | #3 |
Well I took the retractor apart. I cleaned up a small contact switch and adjusted it by bending the contacts in-and-out and got it to work perfectly. Got a chime module from a 4 gen firebird. Now it's back in the truck, light comes on and the chime works just like it should.
06-21-2020, 01:31 AM | #4 |
Congratulations on work well done!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-24-2020, 08:47 PM | #5 |
Well, I thought I was done...but no. Now the light just stays on all the time no matter how far you pull the seat belt out. The belt should come out about 6 inches and the contact on the switch should open the circuit. Well, mine is so FUBAR that it's just closed all the time. Took it apart again and the switch is toast, plastic disintegrated and broken. Now I will just have to find a better switch on another seat belt retractor. If anyone has one let me know belt condition and plastic cover dont matter. Just the switch is important.
Thanks Jay
07-01-2020, 11:19 AM | #6 |
Bad news, No Trucks in Pull-a-part with seat belts. So rather than fix the seat belt switch, I took an easier route. I swapped out the box for 1991-1996 Roadmaster/Caprice box. P/N 10092866
It works great but has some differences from the truck one:
However, for my intended purpose, it works great. The seat belt warning, Key in ignition warning and headlight on warning all work. And I didn't have to replace or recreate the retractor switch. Its alot of trouble just to have the warnings work, but I like it to see things work when they can. Also, during COVID, I had nothing better to do.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project Last edited by Wgesnerjr; 07-01-2020 at 10:24 PM. |
07-01-2020, 08:49 PM | #7 |
Jay
Do you think the 1991-1996 Roadmaster/Caprice box. P/N 10092866 module could be adapted for headlight left on for my old 70? I have a Radio Shack buzzer now but a nice chime would be better. Thanks |
07-01-2020, 10:05 PM | #8 |
Yes, it could be adopted for your 70. However your truck lacks some of the systems to make it fully functional. (Seat belt light, key in ignition warning)
But it could be widdled down to the basics for the headlight minder. First thing is that for your case, a chime module from a 4th gen F-body (Camaro/Fiebird) might be easier to find and wire. It looks like the tan/brown one pictured. P/N 14101255. Make sure it has 7 pins to get the headlight minder option. I also attached the entire wiring callout, but you would only be concerned in 4 pins. C,D,F,H. C=12v Battery D=Parking Lts 12v when on F=Ground H=Key on / ignition 12v Just for reference: there is no A pin. This will yield you just the headlight alarm. It will only sound with parking lts/headlights on and key off. Hope this helps, Jay
07-01-2020, 10:11 PM | #9 |
If it looks like this 6 pin one, it does NOT have the headlight minder option.
07-02-2020, 10:09 AM | #10 |
I used this one, these came from the 88 and up trucks. They have the headlight buzzer.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
07-02-2020, 09:56 PM | #11 |
Thanks for comebacks. Don't know these new cars - are years 98 to 02?
07-03-2020, 12:00 PM | #12 |
Camaro/Firebird 4th Gen 93-02
Caprice/Roadmaster 91-96
