07-06-2020, 10:20 PM | #1 |
Leftover Parts: Door Skin, Dash Panel, & other stuff
Trying to get rid of some stuff and make room in my garage. Would prefer local pickup for large items but will ship when possible.
1. SOLD: New Full Door Skin - Right Side. Got replacement doors so don't need it anymore. I paid $75 plus shipping. Asking $50 plus shipping. 2. Center Dash Panel Cut: Bought it a while ago then got an A/C cab and don't need it anymore. Asking $40 plus shipping. 3. Pending Sale to 68Gold/white - Manual Steering Gear Box with Pitman Arm from a 71 C10, although you are probably better off buying a new Pitman Arm. $15 plus shipping. 4. Rochester Carb # 17057504: definitely needs rebuild. $20 plus shipping. 5. Pending Sale to 68Gold/white - Seat Track Brackets from a 71 C10 - got a replacement seat with the brackets, don't need them anymore: $40 plus shipping. 6. Brake Pedal Assembly with or without clutch pedal from 71 C10. Removed the clutch pedal thinking I needed the assembly for my replacement cab. Turned out I didn't. $40 plus shipping. 7. Power Steering Pump with Bracket and 2 Groove Pulley. Switched to Serpentine Belt system and don't need this anymore. $50 plus shipping. 8. Miscellaneous Pulleys & Brackets: $5 each plus shipping. Alternator brackets and Pulleys are SOLD; not sure what everything is for. Just Added extra bracket 9. A/C Bracket for 350 Engine. $15 plus shipping. I had a hard time finding this, then switched to Serpentine Belt after I found it. Asking about what I think I paid for it. 2. Center Dash Panel: 3. Manual Gear Box: 4. Rochester Carb: 5. Seat Tracks: 6. Brake Assembly with Clutch Pedal: 7. Power Steering Pump with Bracket: 9. Added 7/7/20: A/C Bracket for 350 Engine.
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 Last edited by DD1; 07-13-2020 at 11:20 PM. |
07-06-2020, 10:23 PM | #2 |
Re: Leftover Parts: Door Skin, Dash Panel, & other stuff
8. Miscellaneous Brackets & Pulleys - $5 each plus shipping:
C. G
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 Last edited by DD1; 07-13-2020 at 11:22 PM. |
07-06-2020, 10:56 PM | #3 |
I’ll take the 2 pulleys, and the 2 piece non chrome alternator brackets (Last pic) the bigger bracket, a the 2pc chrome one with the hardware.
07-06-2020, 11:00 PM | #4 | |
Send me your zip code and I'll check shipping. Does Paypal work for you? EDIT: Wait you want 4 items - you also want the 2 pc Black Alternator bracket in the last pic. I didn't know that was an alternator bracket. So, $20 plus shipping then.
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
07-07-2020, 07:20 AM | #5 |
I know it is confusing, so I want the single and triple pulleys
The items in picture D and E and the long bracket in F So there are 6 pieces plus the hardware to go with picture D Make Sense? $30 plush shipping I love in Connecticut 06524 is the Zip Let me know the total and I will pay pal you Thanks! |
07-07-2020, 08:35 AM | #6 | |
Here's a pic of everything you want just to be safe. Let me know if anything is missing. All the chrome hardware is in the ziploc bag.
07-07-2020, 12:23 PM | #7 |
The part # for the carb is on the side that the throttle linkage attaches. I am interested but would like the # if possible. Did I see power steering pump brackets? If so how much?
D Page |
07-07-2020, 12:52 PM | #8 | |
I am asking $50 plus shipping for the Power Steering pump with the bracket and pulley.
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 Last edited by DD1; 07-07-2020 at 01:29 PM. |
07-07-2020, 02:06 PM | #9 |
I will purchase the seat brackets and the steering box.
I don't use paypal. can send check or money order. Need to know your method of shipping, to determine which of my ship to, addresses I will use. PM me if this is OK. Thanks Jeff |
07-07-2020, 02:15 PM | #10 | |
I will see if it will fit in a Priority Mail Flat Rate Box. Otherwise I would price out USPS, Fedex or UPS Ground and see which is the lowest rate. Thanks! Darien
07-07-2020, 02:59 PM | #11 | |
Thanks!!! I don't use any of those transfer deals. Let me know when you find out. No rush on your end!!! Jeff |
07-07-2020, 03:13 PM | #12 |
What zip or address do you want me to use?
07-07-2020, 03:38 PM | #13 |
Just sent you a PM with info.
07-07-2020, 07:22 PM | #14 |
Thanks! Saw your PM and responded with info.
07-08-2020, 12:26 PM | #15 |
Door Skin is pending Local Sale.
07-09-2020, 09:18 AM | #16 |
Ttt
07-10-2020, 02:13 PM | #17 |
Ttt
07-11-2020, 12:19 PM | #18 |
ttt
07-13-2020, 11:24 PM | #19 |
ttt
