Old 07-01-2020, 06:17 PM   #1026
layinrocker65
layinrocker65's Avatar
Re: A '54 named Busty
better go camping before our great CA leader makes it illegal again
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 07-01-2020, 06:35 PM   #1027
Gregski
Gregski's Avatar
so true
Gregski is online now   Reply With Quote
Old 07-06-2020, 01:55 PM   #1028
texxxan
texxxan's Avatar
I hope you enjoyed your camping trip.
texxxan is offline   Reply With Quote
Old 07-06-2020, 08:09 PM   #1029
Gregski
Gregski's Avatar
thanks, yes we did, it was rad and much needed, I am now trying to get motivated to walk into the garage and do the fuel plumbing...
Old 07-07-2020, 12:46 AM   #1030
Gregski
Gregski's Avatar
mandatory stare and compare
stock sending unit vs the sump pump
Old 07-07-2020, 12:48 AM   #1031
Gregski
Gregski's Avatar
and here's a little close up, I got this sending unit with the screw on couplers for a reason so I was not going to cut them off and use the compression AN adapters, it took me a while but I got the right AN adapter that simply screw in, I like this clean setup
Old 07-07-2020, 12:50 AM   #1032
Gregski
Gregski's Avatar
and she's in, these sending units come in two different clock positions but this one is good enough for me as long as it fits I can route the steel braided lines accordingly
Old 07-07-2020, 12:54 AM   #1033
Gregski
Gregski's Avatar
I swear would it kill 'em to label the return line on this Corvette fuel filter regulator?!?!?! had to find a labeled diagram to run the lines the proper way as it sure aint intuitive at all and the stubs are not long enuff to tell a 3/8ths from a 5/16ths
I know there's an arrow but I took that as directional flow from tank to engine, all I want is a little "R" next to the proper nipple ha ha
Old 07-07-2020, 07:39 AM   #1034
texxxan
texxxan's Avatar
I never paid much attention to this before. Thank you for pointing this out. I will have a head start now when I do my conversion.
Old 07-07-2020, 10:35 AM   #1035
Gregski
Gregski's Avatar
no worries my friend this is why I try and document, majority of this is discovery and if I can help someone else out, that's a bonus, and I find myself referring to my own build threads years later, cause you blink and it's been 2, 4, hewk 10 years since you done did something (and hopefully she's still running, ha ha)
gonna spend most of today cutting up my thumbs whilst attempting to make more steel braided fuel lines, I found some great Fragola brand -6 AN fittings I've ran them in the past so it's just a matter of cutting the lines and putting them on
end is in sight!
Old 07-07-2020, 08:40 PM   #1036
Gregski
Gregski's Avatar
Spaghetti Western
Old 07-07-2020, 08:41 PM   #1037
Gregski
Gregski's Avatar
Injector wires in place (approximately) we fully expect to make adjustments as we go
Old 07-07-2020, 08:42 PM   #1038
Gregski
Gregski's Avatar
added the coil wires...
Old 07-07-2020, 08:44 PM   #1039
Gregski
Gregski's Avatar
added, alternator wires, TPS, MAF, Temp, you get the idea, we just keep building and building...
Old 07-07-2020, 08:45 PM   #1040
Gregski
Gregski's Avatar
and pretty soon all that was left was the Transmission branch of wires to run...
Old 07-07-2020, 10:01 PM   #1041
Wide Open
Looking good
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 07-08-2020, 08:23 AM   #1042
8man
Man that looks like fun! Almost road worthy.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 07-08-2020, 10:15 AM   #1043
texxxan
texxxan's Avatar
What is the Fun Meter on all this wiring?
Old 07-08-2020, 10:42 AM   #1044
layinrocker65
Wiring is the worst, such a pain. I like to use small zip ties to hold it all together as I go. They are easy to cut off, no adhesive to deal with and you can pull wires out of them if needed. Probably go through a few hundred when building a car.
‘53 GMC COE stock
Old 07-08-2020, 11:02 AM   #1045
Gregski
Gregski's Avatar
ha ha, I love a brother who follows along and reads the thread, well, I think my mamma must have dropped the PCM on my head too many times, cause I actually enjoy wiring so we give it a high score of ... [wait for it] ...
Wiring Fun Level (WFL) = 8.0
Cons - old sticky tape gets your hands dirty, nice and black unless you wear gloves to undo it all
Pros - WYSIWYG What You See Is What You Get, ie you get immediate recognizable results, unlike rebuilding an engine for example and having to wait weeks or months to hear it fire, I hope that makes sense
Old 07-08-2020, 11:06 AM   #1046
Gregski
Gregski's Avatar
I hear you brother and thank you for the advice I will give the little ones a go, I know that the old tape I used the lighter in color with writing on it, (which you can no longer buy, darn it) was super easy to work with and do and undo and reuse, the darker one is much more difficult to use
Old 07-08-2020, 11:10 AM   #1047
8man
Yep, hook up that multimeter and you have a winner...or a looser and you re-do it.
I've not done the thinning of the PCM like you did, and I hooked it up with with all the connectors attached to the wires, but it does looks interesting. Where/how did you learn to thin the harness?
8man-aka Robert
Old 07-08-2020, 11:11 AM   #1048
Gregski
Gregski's Avatar
so all these wires will get shortened and new pins crimped on,
FYI the PCM uses two different size pins the pin side is the same size but the part that grabs the wire is two different sizes depending on the gaugeness or thickness of the wire
Mouser part numbers: 829-15359001 $15 for 50 and 829-15359002 $20 for 50
I decided to mount the PCM to the firewall on the passenger side for the following reasons
  1. closest to the battery and the starter so shorter wire runs
  2. offset the weight of the driver (for racing purposes - yeah right!?)
  3. thought about running the PCM on the inside of the cab but the PCM belongs in the engine bay (became lazy and talked myself out of it)
Old 07-08-2020, 11:12 AM   #1049
8man
But where does the AC go?
8man-aka Robert
Old 07-08-2020, 11:17 AM   #1050
Gregski
Gregski's Avatar
ha ha, I'm only 48 so I have another 2 years before the mandatory old man accessories go on, and if I ever install a tilt steering column you come over and punch me in the neck, hee hee
