#1051 | |
![]() Join Date: Aug 2014
Re: A '54 named Busty
2003 Vortec 5.3L Wiring Harness Rework Part 1 |
#1052 |
![]() Join Date: Sep 2017
Aren't you the same guy who was posting temps because it was so hot?
Also, why is a tilt an old guy accessory?
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#1053 | |
AC, tilt, cruise control, power windows, power seats, not necessarily old man accessories just don't belong on a Hot Rod, those who do miss the point - less is more (and I'm right and everyone else is wrong, ha ha) |
#1054 |
Had not seen his video. I will be watching it, thanks. I'm thinking LS for the 54. I mean what old guy needs more than one carb'd truck?
#1055 |
#1056 |
Turbo? Hmmmmm
#1057 |
![]() Join Date: May 2007
nice wire monkeying!
#1058 |
#1059 | |
I'm just getting caught up here. I didn't mean for you to really do it... Twice... So far... |
#1060 |
#1061 | |
Re: A '54 named Busty - Setting The Engine Pinion Angle
#1062 |
Now who's the poet...
#1063 |
#1064 |
the latter and I know my garage slopes forward (as evident by a pile of sockets in the two front corners of the garage at the end of each project, ha ha) however when I set that dial gauge on my garage floor the rise over run was negligible so I called that a zero and shot for 3° of engine slope downess towards the rudder
#1065 |
we observed a couple days of no spoken word after she gently moved my thinned out and perfectly laid out wiring harness in the middle of the wiring [ahem] living room to my office
#1066 |
gonna roll my own fuse block
simple design, two relays, a main power relay and one for the fuel pump |
#1067 |
Cool. I have a similar setup for headlights, fuel pump, etc. I like it a lot.
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
#1068 |
#1069 |
cutting, taping, thinning
extending, soldering, untaping, zip tieing, doing it again shortening, lengthening, arranging, rearanging, doing, undoing, removing, adding, heat shrinking, wrapping, unwrapping... doing it again! live to swap swap to live do or die revving high Last edited by Gregski; 07-11-2020 at 12:30 PM. |
#1070 |
I should be able to get you one next week. I’ve moved beyond the wiring room living phase (at least for now) and she at the body shop getting an estimate.
#1071 |
#1072 |
scored a PCM tray out of a '97 S10 - I really like these as installation is a snap! ha ha literally
#1073 |
just waiting on more parts to finish up the fuel lines and the wiring harness, was hoping to fire her up this weekend but that may not happen now
#1074 |
That sucks! A perfectly good weekend and waiting on parts. I'm sure you can find something to work on, so it will still be a good weekend.
#1075 |
Ah yup, progress not perfection
