adhesive removal- dash
Looking for recommendations to get adhesive off of the dash, previous owner had a carpet mat on the dash and had it Velcro or glued on, dash is in good shape but has big strips of adhesive all over it. What can I safely use to get that off without ruining the dash?
#2 | |
Re: adhesive removal- dash
https://googone.com/howto/blog/does-...-work-on-that/ It may affect the color. |
Spray brake cleaner on a cloth, test in unseen area. If ok, wipe away..........
![]() Join Date: Oct 2009
another vote for goo gone. I believe brake cleaner will damage paint.
Iv'e used Varsol ( paint thinner ) on stuff with good results
#6 | |
I all so used cup hot water and plastic razer blade in the high heat direct sun light lots of elbow grease and what energy work out.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Normal automotive vinyl cleaner.
Hot soap and water. Rubbing Alcohol. |
Thanks for the tips, I'll try some of these options and post the results for everyone
![]() Join Date: Oct 2018
Have you had a chance to try out any of those products on your dash?
I’m in the same boat as you. Old glue all over the dash. |
