#26 |
Where's my beer?
Re: How do you protect your investment from theft ?
Clutch pedal eliminates a damn lot of drivers these days!
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
#27 | |
![]() Join Date: Feb 2009
I had a kill switch with my HEI, I'd like to install the switch again, just not where it was. There was a time I left it out and locked the steering wheel, removed the battery terminal, locked the doors and flipped the kill switch. Today that wouldn't be enough. I'm not so concerned about my 72, but I'd sure miss the wheels ![]() There's all kinds of things you can do, the more obstacles you create for the bottom-dwelling maggots the better chance it will be where you expected it. As my garage goes I can save them the trouble coming through the door, they'll need more than a B/A sledge hammer ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#28 | ||
Who Changed This?
![]() Join Date: Jan 2013
I like the cell phone one mentioned earlier. It's a ton cheaper than a Lo-Jack. My truck is quick off the line and I truly enjoy getting a hole shot across an intersection on some ricer with a 4" fart can in the next lane, but this truck isn't even going to outrun Motorola. ![]()
#29 | |
My area is undergoing a big change giving reason to be (not feel) less comfortable. Many areas are, I just happen to border Ca. I block mine as well, it's not even drivable ![]()
#30 |
Grounding the tach is a great way to kill the ignition without disconnecting something that might be obvious to someone with a little knowledge. I've been thinking about a fuel shutoff solenoid so it would run out of fuel a short distance from where they grabbed it hopefully in the middle of a busy intersection most would just run at that point. Right now mine is in paint jail but soon out, it's a manual and if I am letting it out of sight I unscrew the shifter and take it with me. Made locks for my tow hooks too.
72 swb 4x4 dana 60 14 bolt ff nv4500 np205 66 SS Chevy II 67 Chevy II 2dr sedan |
#31 |
![]() Join Date: Jul 2015
#32 |
First of all if you think of this hobby as an investment you need to get out sorry to say.
But Good insurance is the only way . If someone wants you vehicle bad enough it's gone no matter what you do. My 66 ss is valued at 65k . And I drive it to lowes home depot walmart you get the idea and car shows. I'm driving my burban all over as we speak . Sits in the lot with the other cars and trucks at the hotel
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#33 |
Who Changed This?
Ya'll need that James Bond Electro-shock device!
#34 |
Funny, my new neighbor has a real nice car hauler in his driveway, might be his friends. They're away someplace, so he parked his Dodge sideways to block it. I'd rather lose a Dodge than that trailer too, good decision
![]() ![]() I think end the end, it's just better we don't leave our trucks anywhere we're not if we can't take the long-term emotional pain of losing one ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-14-2020 at 05:02 PM. |
#35 |
I've taken my hot rods on the Power tour and other big car shows. Had to stay in hotels in towns I didn't know well at all. But as the anti theft device I use is small bolts thru my drilled and slotted rotors. All four wheels. If someone tries to move the car/truck the bolts will jam on the caliper mounts. They are not easy to see and thieves want to be away fast. Even if they had a roll back wrecker they would have to drag out of the parking spot creating a lot noise. I'm running a LS so I also pull the fuel pump fuse.
#36 | |
#37 |
No need to hide a kill switch, just take it with you. Place the receiver unit under a locked hood.
https://www.ebay.com/itm/DC-12V-433M.../352665735266? |
#38 |
![]() Join Date: Jun 2017
I had my truck appraised and insured with hagerty
#39 |
Best way to protect it is insurance. The next best is to keep it parked inside in a locked location.
Kill switches, pulling fuses, etc. are all predicated on the thief trying to drive off with the vehicle. That rarely happens anymore, simply because modern cars are WAY less susceptible to hotwiring. People just pull up with a tow truck, yank it on to the flatbed or lift the tires, and drive off. Much less suspicious-looking than breaking in and hotwiring. Guns are also predicated on you being there when it happens, and in most cases, you simply being there, gun or not, will deter someone looking for an easy theft. Besides, as much as I love my truck, I'm not killing someone over it. That's why I carry good insurance. |
#40 |
![]() Join Date: Aug 2019
I use a ignition disable switch. Mine, i"ll keep secret. But something like a dummy choke knob. When pushed in the truck won't start.
#41 |
Who Changed This?
As for someone just dragging my truck out of the driveway with a hook, not much I could do. But if I saw it happening, my .357 will make short work of the engine block, which is what it was developed for. Maybe some tires, too.
![]() ![]() Maybe keep my pickaxe (or my 5 foot long prybar as a javelin) by the front yard and punch through the grill into the radiator. ![]()
#42 |
![]() Join Date: Mar 2003
I actually had a dream last night that I owned a crew dually 4x and came out to the parking lot with somebody under the hood trying to steal it. I've had other dreams in the recent past of coming out to not owning a truck anymore. Just up and disappeared overnight. I owned a K5 years ago that I converted to 3/4 ton axles and built up the rest of the drivetrain. Of all things I had a locking hasp under the hood that had to be released before the lever would lift. worked out pretty sweet. I'm considering one of the cable locking systems for the hood on my keeper---the flat bed dually. Eventually going to sell both my 68 chevy longhorn and 68 GMC. Too many trucks to keep up and maintain with registrations and insurance. Calif is not cheap
#43 |
There used to be an elderly farmer near where I live who started farming in the late 40's had a John Deere A, G, a 630 and, an old C/60 at his estate sale none of them ran and the auctioneers didn't know why? The farmer after he was done using them would take the points out of the distributors
#44 |
Somebody mentioned Streetview, you can enter your address and have them remove images of your address from it. Lots of people are privacy focused these days so it doesn’t necessarily make thieves think you’re protecting anything.
For home, garage or not, a camera security system is a must in my opinion. A hardwired Power Over Ethernet (one wire per camera) system isn’t that hard to install and is more reliable and not able to be tampered with like a WiFi setup. Plus if you tell your various insurance companies about it you may receive discounts. I know someone who had a flatbed backup to the vehicle blocking his nice vehicle, driver got out, saw the cameras and hopped right back in his truck and left. All caught on camera and reported to the police. For when you’re out, gps is your best hope of recovery in my opinion. An easy route here is an older iPhone secured to the underside of the seat with inconspicuous wiring to keep it charged. There’s lots of inexpensive options for phone plans these days, pay as you go, add a line, etc. And if you’re prone to losing or breaking your phone you’ll have a spare on hand. Lastly, be aware. You can’t predict when a professional thief you can’t protect against will happen upon your vehicle but you can minimize risks. I keep those gas station conversations brief and lacking details about me and my vehicle. A regular person may think you’re a bit uptight but a thief will see you as weary and not easy prey. Pay attention to who is behind you on your way home. If I see the same vehicle behind me for awhile on my way home I just pull over and hang out for a minute before continuing home. On more than one occasion I was actually being followed home and the person pulled up next to me, wanting a conversation or to see if I’d sell. Maybe they were geniune, maybe it was an excuse and they were a bad actor. Either way they didn’t find out where I live.
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” Last edited by Overdriven; 07-15-2020 at 11:49 AM. |
#45 |
![]() Join Date: Sep 2003
Here's an idea that has been mentioned but with a nice twist. If 4 minutes is too long, I suggest starting at the 2 min mark.
https://www.youtube.com/watch?v=ZYseqQSlPxQ |
#46 |
![]() Join Date: Feb 2001
Hidden ... Kill switch and good insurance just in case.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#47 |
Great info,
Thank you everyone ! I have never worried about a build that was not complete being stole. Thieves are lazy and do not want to work to complete a project. I live in the Foothills and my sister does not even like coming to my place when I am not home because of my dogs, (my dogs love Chevy trucks too!) I have a Son -in- Law that is a cop in Vacaville CA and he said the best deterrent was the club that locks onto the steering wheel. I understand the electrical circuit cutoff systems. I understand the I have a gun system. These trucks are supposed to be enjoyed ! I am curious about something that will protect the pickup any where, any time with an older teenager in charge My daughter loves her truck and wants to take it to college. I feel it will be gone the first weekend in the city (Davis) Just looking for other thoughts & experiences Thanks Jerry
48 CJ2A 63 1500 GMC (LS1 w/ Muncie 4spd) 68 RS Camaro 71 K20 BBC & granny 4 speed 95 2500 4x4 17 HD2500 4x4 Want => 67 C10 short bed w/ Manual Tranny |
#48 | |
#49 |
I've been watching this thread with great interest so I can think down this path when my truck gets closer to road worthy. Right now with entirely no front end, starter, alternator, or fuel line short of a roll back stealing it out of my shop it's pretty safe. Plus, if that were happening while I were gone I have at least two nosy neighbors that would come see what was happening.
Also, my truck is manual, 3OT so that excludes many new age thieves unless they are well versed. I am more concerned about stealing pieces and parts than anything else. Reminds me of my teenage years after saving money for months on end to buy a complete Kenwood stereo/speaker system. As I threw all the Kenwood stickers in the trash one of my buddies asked me why I wasn't going to put one on my back glass. I told him I wasn't going to advertise to every thief around what I had.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#50 | |
