Old 07-17-2020, 07:51 PM   #1
CG
BlahBlahBlah
Clean winch and bumper install
Its on a Blazer but obviously would work on any of our trucks. I liked the clean install, and the over all look is great. Not too in your face like a lot of big bumpers and winch combos. No idea whos ride it is. I probably saw it at Goodguys or something.
Old 07-17-2020, 08:32 PM   #2
clay68c10
clay68c10's Avatar
Re: Clean winch and bumper install
That is clean. No laser cut brand names, or expanded metal, or diamond plate BS.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-17-2020, 08:35 PM   #3
kwmech
That is nice, I like the pan underneath protecting the winch drum
Old 07-17-2020, 10:22 PM   #4
gmc684x4
Nice clean not having a 8274 winch seems out of place
Still have my dads 8274 on my trailer going to put it back on the truck soon as i get her going again
Problem i found most winch bumpers are north of 2500 and the ones not have ugly laser cut branding
gmc684x4 is offline   Reply With Quote
Old 07-17-2020, 10:27 PM   #5
gmc684x4
I dont mind diamond plate on top in snow mud ice gives more footing grip
Nothing like smashing your leg bad slipping because you climbed up to check something
I had a real beafy tube bumper on my 68 from dads 72 first winter i realised why he took it off for a stock bumper he scored
Old 07-17-2020, 10:49 PM   #6
Yep, diamond plate has it's place. Then the world discovered it and it became overused. It's still right for it's intended purpose. I always placed the 71/72 turn signals behind the grille. They match the dimensions of 6 grille rectangles perfectly. I even cut a grille out to fit them in one truck many moons ago. Behind w/o cutting is best
Old 07-17-2020, 11:06 PM   #7
Getter-Done
Getter-Done's Avatar
Thanks for posting.
That gives me a few Idea's.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 07-18-2020, 03:52 PM   #8
Chevyland
Chevyland's Avatar
I’ve never seen this done before
Does anyone have pictures of it
I’ve said it before
Winches look better on 69-70
Because of where the turn signals are mounted
I’ve always thought, the mounting of them on
The winch
Looks Jenky
Chevyland is offline   Reply With Quote
Old 07-18-2020, 04:12 PM   #9
70cst
70cst's Avatar
Very very nice
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-18-2020, 04:15 PM   #10
I can find pictures of my '71 C/30 tow truck with push bumper with them behind the grille, upper/outer corners. I'm not sure they'll show. I cut out the grille on a K/20 I had because it had a lot of cracks from hitting a big bird. I may have an old print I've never scanned. I ended up putting in a '70 grille, thinking same as you said.
Old 07-18-2020, 04:21 PM   #11
68panelman
68panelman's Avatar
Looks great, the metal housing that mounts on top doesn't look to bad either for the directional lights, after all, it is a warn clone. That cowl hood fits darn nicely too, best I've ever seen with fender lines looking like that
68panelman is offline   Reply With Quote
Old 07-18-2020, 04:40 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Turn signal mounting looks like an after thought.
Check this one out a member just did: http://67-72chevytrucks.com/vboard/s...d.php?t=808840
Old 07-18-2020, 07:27 PM   #13
Is this Cleskie's Blazer a good while back?
Different strokes, I guess. I think the signals are placed well, like he thought it out. On top would look like an after thought to me. Hidden hitches behind factory bumpers are cool, but this is about a traditionally mounted winch in a winch bumper that looks clean. I'm old school and like the traditional era-correct look. One day I want to make a Warn-looking bumper and do the same type of job. I 'want' the winch to be seen and I 'want' it mounted in a traditionally styled winch bumper
Old 07-18-2020, 07:44 PM   #14
68panelman
68panelman's Avatar
This is the metal directional light housing I'm talking about
Old 07-19-2020, 09:36 AM   #15
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I’ve said it before
The winch
Looks Jenky
Here's what I did on mine. The bumper is a square body Warn. I made brackets to fit the 72. The parking/turn signals are LEDs behind the grill.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-20-2020, 02:55 AM   #16
mrtoni
Mounts are pretty much the same dimensions? But gave to drill new holes right?
mrtoni is offline   Reply With Quote
Old 07-20-2020, 07:42 AM   #17
Yep, that's how Warn did it. That's why I think the under bumper is better thought out. Looks better, cleaner, being somewhat hidden and you get the full step for servicing under the hood.
Sharp looking set-up
Yes, just need to move forward a bit to compensate for the peaked nose of the '67-'72 compared to the flatter '73-'87. I recall being able to use existing holes in frame and only drilling one on each side
Old 07-20-2020, 07:45 AM   #18
Ol Blue K20
No the square body mounts are too short. They also put the bumper an inch and a half lower. I didn't like it below the grill. I mounted my lights behind the grill to protect them. The OP is under the bumper. I would be afraid they would get crushed or torn off.
Dale
Old 07-20-2020, 08:47 AM   #19
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Mounting the turn signals inside the grille does look clean
Old 07-21-2020, 09:58 AM   #20
Ol Blue K20
Thanks, they're also a little more protected for off road conditions
Dale
Old 07-22-2020, 06:25 AM   #21
Yeah, I'd want them "housed" in steel under there
Old 07-22-2020, 08:54 AM   #22
Ol Blue K20
One little bush could break them up without some kind of protection.
Dale
Old 07-22-2020, 10:38 PM   #23
toolboxchev
Talking Re: Clean winch and bumper install
I really like the clean underside look with the plating covering up stuff that is normally exposed.
toolboxchev is offline   Reply With Quote
Old 07-23-2020, 08:21 AM   #24
How would you know? It's true, it wouldn't take much and those tiny bushes are not a concern from the driver seat. I've bent the tie-rod on a stump that was just a bit too tall that I did not see. But, if plate steel hoops surrounded them the worst likely damage would be a broken lens. Look at the rear on some many trucks and trailers and you'll see many that are surrounded by steel that makes the light recessed
I am still wondering if this is Cleskie's Blazer before the camper and before he went to steel wheels. He's had it a long time and it once had 16.5 aluminum slots. He also has 8-lugs. I guess he drifted off to Instagram or other
Old 07-23-2020, 08:34 AM   #25
Ol Blue K20
I don't know who it belongs to or how old that pic is. It's one nice looking Blazer though.
Dale
