06-08-2020, 03:51 PM | #76 | |
Re: Cgt project
06-08-2020, 07:36 PM | #77 |
Re: Cgt project
Thx, I have a lot of fun with it.
06-25-2020, 08:42 PM | #78 |
Re: Cgt project
Had a rendering done for the Cgt.
06-25-2020, 11:07 PM | #79 |
Re: Cgt project
Whats the color?
06-26-2020, 12:04 AM | #80 |
Re: Cgt project
06-27-2020, 11:46 AM | #81 |
Re: Cgt project
Getting close to start laying paint and thinking ahead. I will be buying a complete side trim kit, but I don't want push in style clips. I would rather have threaded studs as I can then adjust and I find they are way easier to take off.
Anyone one know who makes them as all the kits I see have some threaded and some push in. |
06-27-2020, 02:02 PM | #82 | |
Re: Cgt project
06-27-2020, 07:47 PM | #83 | |
Re: Cgt project
06-27-2020, 08:57 PM | #84 |
Re: Cgt project
These are pictures of a 61 Blazer built by Sicchops. Notice in the jams how I assume they filled the metal folded over from quarter in jam and also on door. It really cleans things up. I have been thinking of doing this on my truck. Would there be any downside? |
06-27-2020, 11:41 PM | #85 |
Re: Cgt project
On a full custom ride I don't think it would be a concern.
06-28-2020, 12:24 PM | #86 |
Re: Cgt project
I imagine for a daily, as long as moisture can drain out the bottom, it should be fine.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
06-28-2020, 06:56 PM | #87 |
Re: Cgt project
I've talked to a couple buddies that are body men and they say the proper way would be weld up the seam then fill. They also said it would likely be fine just filling since I have sealed the inside of the doors with paint.
Its funny how different locations do stuff. I have purchased several vehicles from down south and have come across repairs where they drilled holes to pull out a dent and then smeared bondo into the holes, and called it done. Up here we get a lot of rain and if someone repairs it that way, the paint bubbles quick. |
06-29-2020, 10:16 PM | #88 |
Re: Cgt project
Well, I'm doing it. I am using a fiberglass body filler as it is stronger.
06-30-2020, 10:21 PM | #89 |
Re: Cgt project
No more seam. I like it better. |
07-01-2020, 08:33 AM | #90 |
I'm just glad to be here!
Re: Cgt project
Looks good. I did the same thing years ago with my '65 that was my daily. It lasted for a long time. Longer than the truck did before someone vandalized it. I let the truck sit for about 5-6 years before reworking it and the jambs still looked really good.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-18-2020, 06:26 PM | #91 |
Re: Cgt project
This has been my Covid isolation for the past 4 months. Nice to have some colour on it. I plan to let all the parts bake in the sun until September then reshoot it.
07-19-2020, 03:28 AM | #92 |
Re: Cgt project
Jeez.... Hustle. Serious hustle.
07-19-2020, 10:33 AM | #93 |
Re: Cgt project
really nice work!
08-21-2020, 04:57 PM | #94 |
Re: Cgt project
When your out of room and you need somewhere to assemble your Cgt frame.
08-27-2020, 06:40 PM | #95 |
Re: Cgt project
I like this part of the build best. Goes together pretty fast.
08-28-2020, 09:19 AM | #96 |
Re: Cgt project
Drivetrain envy
09-18-2020, 01:32 PM | #97 |
Re: Cgt project
I am in the middle of final paint and just sprayed my side trim stripes a contrast colour. I just masked in the center of the trim holes. In reflection was this a mistake? Was thinking will the stripes lineup at the cab corner to door? Does it really matter as the trim cover most of the paint lines? I had checked my trim alignment on mockup to make sure they were straight. How does everyone else do it?
09-18-2020, 01:35 PM | #98 | |
Re: Cgt project
09-18-2020, 01:44 PM | #99 |
Re: Cgt project
Thx. I was just worried that looking at the side of the truck if the stripes had some misalignment (higher or lower or width) that you might see it in the jam, or would you notice it ?
09-20-2020, 10:47 AM | #100 |
Re: Cgt project
Man what an awesome build! Always thought a GT built C10 would be super cool. Can't wait to see what you do with the interior.
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
