05-07-2020, 07:55 AM | #101 |
Re: Period Correct Accessaries for your truck...
I hang mine on the glovebox door. It helps to adjust the position of the latch.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. Last edited by palallin; 05-12-2020 at 01:38 PM. |
05-11-2020, 10:34 PM | #102 |
Bump
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-12-2020, 12:38 AM | #103 |
Location: Herculaneum MO (20 minutes south of St. Louis
I have a set of these that came in my C20 when I bought it
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
06-01-2020, 11:20 PM | #104 |
Currently Blazerless
I found this awhile back, never used steal plate and
was in its own original mailing sleeve.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
06-02-2020, 12:08 AM | #105 |
Sweet
06-02-2020, 08:33 AM | #106 |
Old member
I took this out of a 68 SS Impala the other week. I took it all a part and cleaned it up repainted it and now putting it back together as I get the parts done. I have to get a detail paint marker to finish the face up and polish out the knobs and it should be done. According to the sticker it's for a 68 model.
First picture is what it looked like when I took it out. Then cleaning the parts and painting them. Then reassembly and the compressor brackets.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-02-2020, 10:32 AM | #107 |
This is a great thread! I love seeing all of this cool stuff.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
06-04-2020, 08:46 PM | #108 |
How did I get this OLD!
I installed the vintage GM aftermarket A/C unit. I like the fit. Just have to install the compressor, dryer, condenser and plumb the unit. The fan and switch operate as they should.
http://67-72chevytrucks.com/vboard/a...1&d=1591317606
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
07-12-2020, 11:06 AM | #109 |
We've talked about Bar Bouys here. I used these for years. When I got my camper I mounted some in there. I still had one I kept but didn't get the base off the truck when I sold it. I have regretted that and have meant to post a WTB on a long shot.
We'll looky here what I found in a box with other things stashed in the attic. I completely forgot I had this. Life is good!
07-12-2020, 11:13 AM | #110 |
Carpe manana
The k1500 I used to own had three bar buoy holders in the cab.
07-12-2020, 01:18 PM | #111 |
Darn, I should have posted a WTB. You might have left the next owner a couple mystery holes . not a mystery with two others remaining, though. I have bought many trucks that had the telltale two holes, usually on the upper door or dash
07-12-2020, 03:02 PM | #112 |
I think someone already posted with their Hickey winch installed but here are some pictures after rebuilding mine.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
07-12-2020, 07:03 PM | #113 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-13-2020, 04:46 PM | #114 |
That’s awesome seeing all of these vintage items
The 71 I used to have didn’t really have any accessories other than a GM radio
1971 GMC Sierra 1959 GMC 100 |
07-13-2020, 10:35 PM | #115 |
The gentleman who ordered my truck new went a bit crazy with the dealer installed options. Including, sun visors, bumper guards, bumper mounted unity driving lights, unity spot light, and these rear bumper steps Ive never seen before or since.
07-14-2020, 12:23 AM | #116 |
And I like them steps
Posted via Mobile Device |
07-14-2020, 01:02 AM | #117 |
How about an original aftermarket racing sticker that is still on my tailgate.
Frankland Quick Change Rear Ends. The second image is a sticker sold on ebay. My understanding is that it is not the same company and has a slightly altered name. They do use the same cartoon character and make quick change rear ends?
'67 GMC 2500, 292, 4spd, AC |
07-15-2020, 07:59 AM | #118 |
Cool stuff! I have a faded original from the era Harley Davidson extended bar & shield emblem on my sliding back glass. It's a real decal.
That Hickey winch came out beautiful. I remember those GM accessory rear bumper steps. Never saw many, though. I just notice this accessory that fits this thread. "Honey, where did you put the key to the truck?" "Where did I put the key?. You were last to have it"
07-15-2020, 05:22 PM | #119 |
Folks ... you have really shown some cool aftermarket accessories ...
07-18-2020, 04:30 PM | #120 |
Any other period correct accessories? I am enjoying this thread.
07-19-2020, 09:36 AM | #121 |
07-19-2020, 10:27 AM | #122 |
Don't know how to link to it but there is one of those on Ebay right now. Buy It Now for $27.97 with $9.98 shipping. Item 333 609 640 019
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
07-19-2020, 10:29 AM | #123 |
Thanks for heads up and item number. Have spent 39 bucks on more stupid things. Thanks. Just went up on flea bay and bought it. Now I have something to fill those holes and my son will have somewhere to put his hat too.
07-19-2020, 05:48 PM | #124 |
Those are cool options
07-19-2020, 05:54 PM | #125 |
I have one of these GM compasses, I bought it at a dealership in the '80s or '90s. After a long time cooking inside a truck cab in AZ, the oil is leaking out, and the North alignment is off.
Anyone know what the fluid medium is inside? Mineral oil? I think I could inject some more and seal it with a dab of epoxy. They have shot up in price now. I like a magnetic compass as a back up to the GPS.
