07-31-2020, 03:20 PM | #1 |
Scanningr for codes
When I scan the computer where it shows ready to fire and all that, two lines show 025 and H025 not ready. Could this be a problem with the tune ( I am battling P0171 and P0174 codes) or is it something that was deleted? Also, does anyone have the part number for the vacuum port for the brake booster on a 2007 4.8. I would like to replace mine to eliminate a possible cause for my supposed vacuum leak. Thanks, Tbrown
tbrown's 56 Cameo Build |
07-31-2020, 06:01 PM | #2 |
Moderator
Re: Scanningr for codes
Passenger side of intake manifold on side of top chamber is a vacuum port usually used as a blend door vacuum source....
If you dont need it, just plug it... What vacuum ports are you wanting to add? Power brakes ?
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
07-31-2020, 09:44 PM | #3 |
I am using that port for vacuum wipers. Not trying to add anything, just trying to find vacuum leak or cause for P0171 and P0174 codes. I have power brakes, and just want to make sure the swivel on the booster port isn't leaking vacuum.
tbrown's 56 Cameo Build Last edited by AussieinNC; 08-01-2020 at 12:49 PM. |
07-31-2020, 11:01 PM | #4 |
It's rare for the booster port o-ring to leak, Intake gaskets are common & the intake itself being cracked is very common on wreaking yard engines.
08-01-2020, 12:50 PM | #5 | |
Moderator
As clinebarger said...intake gaskets and intake manifold leaks, especially under the manifold...
08-01-2020, 11:11 PM | #6 |
Already changed the intake gaskets, but will block off that port and try it. Thanks for the help.
08-02-2020, 10:16 PM | #7 |
If the O-ring is leaking.....There really isn't a way to block it with the quick release mechanism & all.
Though your booster may be leaking.....Clamp/pinch the booster line to confirm. Can you watch live Fuel Trim Data?? A vacuum leak will show as high trim corrections at idle & correct under acceleration. Normal trims at idle & positive corrections under acceleration would be a fueling issue. (MAF, Injectors, Fuel Pressure) |
08-02-2020, 10:41 PM | #8 |
That is new information to me, I will check it out. Thanks
09-02-2020, 09:23 PM | #9 |
Also make sure your pcv on the valve covers are hooked up as this will throw the codes.
09-02-2020, 09:37 PM | #10 |
Subbed for new knowledge......
09-04-2020, 02:27 PM | #11 |
they do sell a plug that will go into the booster hole(used on trucks with hydro boost) spot no longger sold by gm they are a dimond in the rough if u find one everyone wants good money for them i got lucky and soeone here on the fourm sent me one since im using manaul brakes still
