Old 07-30-2020, 08:59 PM   #1
TXGREMLIN
colmn swap
what is all involved with swapping the column out 84-87 into to 78 c10
with column shift
TXGREMLIN is offline   Reply With Quote
Old 07-31-2020, 09:52 AM   #2
Ziegelsteinfaust
Re: colmn swap
It is a bolt in operation as far as the column, but the wiring is different.
The wiper controls, and high beams are on a stalk on the new model. So you will have to re-pin your connector or add a new connector. That way you can add the function to the column.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-31-2020, 12:10 PM   #3
kglowacky
Re: colmn swap
or you can leave the wipers and high beams where they are and not use the new column functions
kglowacky is offline   Reply With Quote
Old 07-31-2020, 12:23 PM   #4
hatzie
Moderator
hatzie's Avatar
Re: colmn swap
The harmonica plug is pinned the same from 78 on.
The wipers and dimmer switches are up to you.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-31-2020, 04:18 PM   #5
TXGREMLIN
Re: colmn swap
is the shaft from the firewall to the steering box the same too.
I want all the stuff on the new column to work like factory.
Old 07-31-2020, 04:36 PM   #6
hatzie
Moderator
hatzie's Avatar
Re: colmn swap
The stub end of the column is shaped differently for different model years.
You'll have to get a steering shaft that mates with your power steering box and column.
Not difficult to find. Some folks use a Jeep intermediate shaft with universal joints rather than a rag joint.
Old 08-01-2020, 03:17 AM   #7
TXGREMLIN
Re: colmn swap
ok so grab the shaft at the same time I snag a column
Old 08-01-2020, 08:08 AM   #8
kglowacky
Re: colmn swap
yes. It may or may not work depending on your steering box end. But you could use one end from your old shaft and one from your new one to make what you need. It would take some work taking them both apart and building what you need but it would work. It could be as easy as a bolt on or a new rag joint
