Old 08-04-2020, 05:44 PM   #1
SBPage1
1961 C30 Brakes
My C30 right rear brake kept locking up. I finally took it apart and found that it was missing the self adjusting lever and associated hardware! UGGGH!! I know that parts for the rear brakes are impossible to find, especially the adjuster lever. Anyone have any idea where I can get one? It’s a HO74 rear end if that makes any difference.
SBPage1 is offline   Reply With Quote
Old 08-04-2020, 11:26 PM   #2
62c30
Re: 1961 C30 Brakes
Not sure on the brake parts I know they are hard to find. I swapped in a 14 bolt and it bolted right in place on my 62 c30 so it would be easy to get parts.
62c30 is offline   Reply With Quote
Old 08-09-2020, 12:39 AM   #3
tchevs
Re: 1961 C30 Brakes
I have used 14 bolt brakes in a HO72 rear end before. The backing plates bolt right in place of the HO72 backing plate. By doing this i was able to use the drums off the 14 bolt. On another note, not sure if this helps but i had a 62 half ton that didnt have that hardware, the 12 bolt stuff fit right on the HO32 brakes. I would check to see if the hardware from a 14 bolt fits?
Tony
tchevs is offline   Reply With Quote
Old 08-09-2020, 03:02 PM   #4
SBPage1
Re: 1961 C30 Brakes
Many thanks TChevs! Learned something new. Before I go the way of the 14 bolt, I’m experimenting with some C20 hardware to see if it works. Ordered it up from RockAuto. Is there any “years” of 14 bolt that work better or all the same?
Old 08-09-2020, 05:32 PM   #5
Joe P
Active Member
Re: 1961 C30 Brakes
I have the same setup on my K20 - HO72 Rear with 13 inch drum. Rock Auto has a hardware kit that is inexpensive and includes the lever. If your drums are good then the kit is the best way to go. Drums are available too but big $$.
Joe P is offline   Reply With Quote
Old 08-09-2020, 07:01 PM   #6
SBPage1
Re: 1961 C30 Brakes
OK...thanks!! Just found them for a 13 in drum and ordered the last two. Went ahead and ordered the left as well. Appreciate you!
