Old 08-10-2020, 07:53 PM   #1326
joedoh
joedoh's Avatar
Re: 53 Surburban "Family Truckster"
good night that is gorgeous!
Old 08-10-2020, 09:17 PM   #1327
NorCalGal
NorCalGal's Avatar
Some people have all the talent. That is a beautiful suburban.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 08-10-2020, 09:49 PM   #1328
youngrodder
youngrodder's Avatar
Thanks man. It is fun to see the vision I've have had for a while bouncing around I'm my head starting to come to fruition.
Thank you very much, I'm humbled. It has been a fun project and so different in many ways from my last build.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-11-2020, 04:25 AM   #1329
MiraclePieCo
MiraclePieCo's Avatar
Outrageous! LOL, you're slightly behind your "couple of years" timetable in post #1 but it's been worth the wait!
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 08-11-2020, 07:54 AM   #1330
youngrodder
Well my first build (48 truck) took 11 yrs, so the way I look at it I'm ahead of schedule..ha ha.
Marc
Old 08-11-2020, 09:55 PM   #1331
youngrodder
So tonight I lined up all of the body mounts so I could slip bolts into each hole. On suburbans there are (4) Wood block 2 5/8" in height the supports the rear wood floor. It takes up the space between the frame and the floor. Since I made my own custom sub floor I knew I would need to make my own blocks.
I used Derlin to make the blocks. Derlin is a high density plastic that is used in tool and die to make worm gears and stuff. I love using this stuff.
1 It comes in black (or white).
2 It's easy to drill, sand and cut
3 it's pretty cheap. I buy drops at Alro metal for a couple $ per Lb.
4 It's not effected by the elements so there's no chance for water damage or rot.
I used Derlin to make my trans and carrier bearing spacers as well.
I needed to locate the body mount hole, drill thru the sub floor structure and make the top hole large enough to drop the head of the 7/16" bolt thru and also be able to fit a socket. Once the wood floor is installed you wont see any of this.
I now have all of my body mounts ready to tighten down as soon as I pick up some 3.5" long 7/16" bolts.
Marc
Old 08-18-2020, 10:05 PM   #1332
youngrodder
I really want to try to get the motor fired this spring. I have been focusing on items to help with that. One thing I noticed after I dropped the body on was my poor placement for the battery. I underestimated how buried it would be under the body. I have since ordered a drop down battery box. The bad part is removing the current one. It will be difficulty to get to the bolts that hold on the mount. I might have to cut it off unless I want to crib up the body some.
We had some friends over this weekend so I bolted the grill and core support cover to look a little more complete. I do like the look of the brushed grill.
Tonight's project, I made my custom vintage plug wires. For not really having the best crimping tools I made due. I like how they turned out. I just need to source some plug wire separators. I also double checked the wiring going into each coil to verify that I had the firing order correct (which I did...I was surprised) coming from the factory harness.
On Sunday I made a small bracket to mount the fuse block for the BPI harness. I'm pretty close to dropping it down the floor and plugging in stuff.
Marc
Old 08-18-2020, 11:31 PM   #1333
joedoh
joedoh's Avatar
beaut work! delrin is some cool stuff. we have an aircraft surplus store here and they sell a composite wood substitute that is also listed as a sub for delrin!
7 months from now? or is your summer cooler and more pleasant haha
Old 08-18-2020, 11:32 PM   #1334
mongocanfly
mongocanfly's Avatar
Spring?...
Those plug wires are cool...never seen them befors..
And that grill....WOW...I really like the brushed look..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-19-2020, 07:59 AM   #1335
reaper71
reaper71's Avatar
Looks great Marc
reaper71 is offline   Reply With Quote
Old 08-19-2020, 08:16 AM   #1336
youngrodder
Typo ha ha...I meant fall. With this Covid crap it has felt like one long Spring.
Originally Posted by mongocanfly View Post
Spring?...
Yeah I meant Fall. I got them off Ebay. They were the cheapest source. They offer a lot of different colors and the guy Tom will provide the ends (45's or 90's) That you need. Thxs I really like to grill as well. Glad I did it.
Originally Posted by reaper71 View Post
Looks great Marc
Thanks Mark
Old 08-19-2020, 01:48 PM   #1337
ajgriffin
ajgriffin's Avatar
Spring?...
Yeah, spring...baseball just started.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 08-19-2020, 11:52 PM   #1338
oldman3
oldman3's Avatar
Really taking shape...Jim
oldman3 is offline   Reply With Quote
Old 08-20-2020, 11:28 PM   #1339
Tempest67
Tempest67's Avatar
Looks great, please post link for those wires, I love the look.
Nice work
Tempest67 is offline   Reply With Quote
Old 08-21-2020, 07:51 AM   #1340
youngrodder
Thanks Jim
Nice work
Thxs much appreciated.
Check out https://www.ebay.com/itm/Vintage-Clo...Cclp%3A2334524
He has many different colors in his various listings. I didn't pay that much, I think my color was discontinued. I bought them last winter.
Marc
Old 08-21-2020, 08:03 AM   #1341
Tempest67
Tempest67's Avatar
Thanks....here I am wanting to replace my wire set and I haven't even started the brand new motor yet....but those look so good.
Thanks for the link
Old 08-21-2020, 09:20 AM   #1342
youngrodder
Thanks for the link
I hear ya. I'm anxiously wanting to fire my motor as well after a complete tear down. I knew that I wanted these wires along time ago. I also purchased some simple black wire separators that I will add to better organize the wires
Marc
Old 08-21-2020, 10:21 AM   #1343
mongocanfly
Marc..couldnt get your Ebay link to work..
I did search it by using (Vintage Cloth Braided Spark Plug Wires) and found them
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-21-2020, 11:42 AM   #1344
youngrodder
I just click on the link and it works for me. Tom's is the guy I bought from. If you want different ends just message him and he will set you up with what you need.
Marc
Old 08-21-2020, 01:22 PM   #1345
mongocanfly
It says.....
(We looked everywhere..Looks like this page is missing.)
But that is the one I saw...
Tons.performance
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-22-2020, 12:56 PM   #1346
_Ogre
_Ogre's Avatar
looking good! getting the body on is a big step
those plug wires look really good. post up a link if you have time
shop air compressor timer
Old 08-23-2020, 06:14 PM   #1347
youngrodder
Thank you...Look up to post# 1340. I posted a link there...
Marc
Old 08-25-2020, 08:02 PM   #1348
joedoh
joedoh's Avatar
you arent kidding! my daughter is still home, since march!
Old 08-26-2020, 08:23 AM   #1349
youngrodder
So one item that surfaced when I dropped the body back on was how buried my battery was. The problems we're A. I couldn't easily unbolt the leads. B. it would be very difficult to remove the battery for replacement. I always want access or a way out on any serviceable item. An example of this is why my rear notch cover for the floor is bold (opposed to weld in) in to allow access to the rear mechanical's. The remedy was not pretty. Because the mounting bolts where hidden behind the battery I had to go mid evil and cut the battery box in 1/2. The solution was a drop down battery box. I love these things. I used one similar on my 48.
Oh...and there's this. My oldest son Cooper turns 16 in Nov. I have been looking for something for him to drive. For years I had driven past a mid 90's 2 door 4-wheel drive Blazer (last year of full size Blazer) sitting next to a barn at a farm by my moms. I stopped by last week to inquire. A deal was struck (For cheap) and we drag it home Friday. This should make a fun father/son project. I needs a fuel pump and some general stop and god stuff.
Marc
Old 09-02-2020, 06:47 PM   #1350
Khaus
Awesome to see all the progress pics of your build!
Khaus is offline   Reply With Quote
