Old 08-22-2020, 10:14 PM   #1
Nodnarb76
Nodnarb76's Avatar
Brake proportioning valve?
So today we tried to replace both front brake hoses. The ends that connect to the hard metal lines were too far gone and will get destroyed when trying to remove them. I am going to have to replace the hard metal lines that go from the proportioning valve to the rubber brake hoses. It looks like I can pick up some from LMC. Where the hard lines go into the proportioning valve look rusty and corroded too. I believe I will have to replace the proportioning valve as well. I cannot seem to find a source for this valve. Does anyone have a link or suggestion?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 08-22-2020, 10:20 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Brake proportioning valve?
Pol has them...https://www.performanceonline.com
Be sure you get the right one for your setup.....and also get the centering tool to hold the plunger centered while you bleed...
But youd be surprised..those lines may come right out..the prop valve should be brass, so the metal wont be rusted to it
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-22-2020, 10:26 PM   #3
mongocanfly
Bleed tool looks like this...you'll need one of these anyway...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-22-2020, 10:42 PM   #4
Nodnarb76
Nodnarb76's Avatar
Thank you the help.
