08-23-2020, 11:10 AM | #26 |
Re: Wheel Vintiques fitment
08-27-2020, 08:46 PM | #27 |
Quick update, went ahead and cancelled the order with wheel vintiques. Found some OG wheels, with caps and trim ring for a smoking deal and went with those. Did a trial fit with the Bell-Tech spindles and coils and happy to report no issues whatsoever. Then again these are original 15x6 wheels and not the 15x7's Vintiques I was originally going with...sooo um yeah I'm a happy camper.
08-28-2020, 09:15 AM | #28 | |
08-28-2020, 02:23 PM | #29 |
clearance is tight, less than a 1/4" but no scraping or rubbing issues. I'm happy I went with the OG set.
08-28-2020, 03:44 PM | #30 |
About what I had on mine. I set out for a stock big & little look so my rears are OE steelie too just bigger/wider. It's a classic, timeless look that's always in style
08-28-2020, 05:06 PM | #31 |
Im going with the 235/75/15 thin white wall all the way around this time. 20" were/are cool but im over that now. This being my first Chevy budget project,( I was a VW fan still am,'62 double cab, 65 sunroof Kombi and my last one a 58 Kombi hence the name robzkombi). I'll just lower it a bit do body and paint, interior and any needed electrical repairs. Keep it simple and enjoyable with a few period correct accessories here and there. So Far so good!
08-28-2020, 05:17 PM | #32 | |
09-18-2020, 10:15 AM | #33 |
Okay so after getting the 235/75/15 wheels mounted to the OG 15 inch wheels and installed on my truck I did have a small issue with grinding. i purchased a 1/4" spacer and although it did minimize the grinding, there was still a slight rub. Turns out it was the clip on wheel balancing weights that were the issue. Went back to Discount Tire and had them re-balance the wheels this time using the stick on weights and that took care of the issue, i'm now a happy camper/trucker.
09-18-2020, 11:09 AM | #34 | |
I had the same issue with Rallyes and wheel weights. They did self clearance on my 1600 mile drive, but I also did run a spacer. I was already using stick on wheel weights unfortunately. Glad you got it worked out! |
09-18-2020, 11:18 AM | #35 |
If you needed/had stick on AND clip on balance weights, something was not right.
