Old 09-03-2020, 10:49 AM   #1
jnova67
63 gmc windshield gasket
I had a windshield installed and the top corners are not sealing right. I bought the gasket from brothers, I dont remember who made it. Is anyone else having this issue?
jnova67 is offline   Reply With Quote
Old 09-03-2020, 11:15 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 63 gmc windshield gasket
If it becomes an issue that is untenable and need to replace it, I would recommend going with a Precision Replacement seal. Mine fit perfectly and installed with ease.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-03-2020, 04:09 PM   #3
forestb
forestb's Avatar
I was going to recommend the same brand. I got steel rubber products and they are way to stiff
forestb is offline   Reply With Quote
Old 09-03-2020, 06:25 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
https://67-72chevytrucks.com/vboard/...d.php?t=568864
I made this thread awhile ago about these year windshields....
Old 09-03-2020, 06:28 PM   #5
forestb
forestb's Avatar
Did you paint your gasket?
Old 09-03-2020, 10:24 PM   #6
vin63
vin63's Avatar
Why, do you? I only used foaming dish soap to ease the install of my windshield and seal.
Old 09-04-2020, 09:40 AM   #7
AcampoDave
AcampoDave's Avatar
Yep, been there done that, had the glass guy come back and remove the inferior gasket and install a Precision.
AcampoDave is offline   Reply With Quote
Old 09-04-2020, 12:40 PM   #8
forestb
forestb's Avatar
No
In your photo it looks like the gasket is painted the same color as the truck below the trim. My gasket seems like it is bulkier than yours either that or your window trim is wider.
Old 09-04-2020, 12:44 PM   #9
forestb
forestb's Avatar
It looks like there is white paint on it.
Old 09-05-2020, 08:28 AM   #10
ls60apache
forest b i believe thats the paint break line you see..he has the wide trim from 60-61 custom cab which covers a good bit of the rubber.
ls60apache is offline   Reply With Quote
Old 09-05-2020, 11:10 AM   #11
forestb
forestb's Avatar
Fancy. I didn’t know there are two types
Old 09-05-2020, 11:12 AM   #12
jnova67
Old 09-05-2020, 11:14 AM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
Is that the same glass you took out to begin with?
Old 09-07-2020, 07:40 AM   #14
jnova67
Had to get new glass. It is pilkington glass
Old 09-10-2020, 03:26 PM   #15
68JOHNDEERE
From the pictures either the glass might be small, or the glass is not fully seated into the pinchweld. When the seal is fully seated the outer fin will sit out on the body. If your seal is not sitting flush against the cab on the inside in the same spots where the issues are on the outside of the cab the seal is not installed correctly.
68JOHNDEERE is offline   Reply With Quote
Old 09-12-2020, 12:55 PM   #16
jnova67
I had a professional install it so i assume it is in correctly
Old 09-21-2020, 07:36 PM   #17
Asshat
Asshat's Avatar
I need to replace my windshield in the 63, and I am not sure if I want to tackle it on my own. If I crack the windshield, I would be soooo pissed.
I'm in Southern California, so I am hoping I can find someone I trust to do this. I would only go with someone that will insure me it will not crack.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 09-21-2020, 09:17 PM   #18
forestb
forestb's Avatar
I could try to get the info for the guy that installed mine. But he is in north Hollywood so I am not sure if he will go all the way down to Orange County
Old 09-21-2020, 09:35 PM   #19
Asshat
Asshat's Avatar
Yeah, that’s a long drive.
292, 4-speed
Old 09-22-2020, 09:30 AM   #20
The Rocknrod
Moderator
Man if I lived around Batavia and Collins area I'd be fat for getting stuff done on my Truck. I drove through there when I visited the Truck Shop and was impressed with the custom car shops in that area. You guys have everything.
Old 09-22-2020, 11:11 AM   #21
forestb
forestb's Avatar
If you are referring to Asshat's post, he is in Orange County CA not NY. Then yes driving for North Hollywood CA to Orange County NY would be a vary long drive for a glass man
Old 09-22-2020, 11:30 AM   #22
Asshat
Asshat's Avatar
I would appreciate the info anyways, might be worth talking to him.
292, 4-speed
Old 09-22-2020, 11:33 AM   #23
Asshat
Asshat's Avatar
Yes, there are quite a few shops around there. I got my seat re-upholstered in Santa Ana for $450. However, I prefer to do most of the repairs myself, I’m not rich. Some of those shops charge a ton of money for simple repairs.
292, 4-speed
Old 09-22-2020, 11:43 AM   #24
forestb
forestb's Avatar
I will see if I can get that for you. The guy that put my truck together is the one who has his contact info. So I will have to get it from him.
Old 09-22-2020, 11:44 AM   #25
forestb
forestb's Avatar
I guess I was the one that was wrong.
