09-03-2020, 12:15 AM | #1 |
WTB - 74+ Rally Center Cap
Original or metal reproduction of ‘74 + 6 Lug Rally Center Cap. Alternatively, looking for plastic emblem appliqué.
Thank you |
09-03-2020, 09:50 PM | #2 |
Re: WTB - 74+ Rally Center Cap
The earliest 6 lug caps look a little different than the newer ones(deeper) You may want to post pictures of the ones you already have. The earlier ones are much harder to find and the base where they met the wheel was black instead of metallic silver.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
09-03-2020, 11:20 PM | #3 |
Thank you. This is a picture of one I have, and I’m looking for another. From your description it would appear I have a later model. I’d also be interested in a set with the 4X4 logo.
09-04-2020, 12:41 PM | #4 |
Active Member
I have these three if its what you are looking for. They are all original GM metal pieces in good shape. Each one has a different part number. Let me know if you want any.
09-04-2020, 02:24 PM | #5 |
If I remember right, the mounting pattern is different on early wheels and caps. I can't guarantee that is the case. It is probably just best to match up your part numbers
09-05-2020, 12:26 AM | #6 |
Thank you for your reply and for taking the time to include the detailed pictures. I will let you know if I’d like to proceed.
09-06-2020, 08:06 PM | #7 |
the early ones have same bolt pattern but the 3 bolts that hold center caps on are a smaller
09-12-2020, 06:18 AM | #8 |
I believe the very earliest rally caps had a somewhat different style. The cone was not quite as pronounced and they actually mounted from the BACK of the wheel with the three cap bolts. No three bolt mounting holes show on the front face. Think I have ONE of those if you would have an interest.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
