Old 08-14-2020, 09:59 PM   #251
jimbosprint
jimbosprint's Avatar
Re: '72 Cheyenne K10
Originally Posted by cj847 View Post
Jimbo,
I am installing a vintage air right now as well. Which hose is supposed to be vertical (ie the dent shape in the cove box)? Is it the passenger defrost or passenger side vent?
I ran the passenger vent in front of the passenger defrost. I don't know if this is correct, but the other way pushed the defrost vent out of the dash.
jimbosprint is offline   Reply With Quote
Old 08-15-2020, 01:54 PM   #252
jimbosprint
Spare tire is mounted in the bed securely. I got the bracket on Amazon for $29 (Rigid Hitch in-Bed Spare Tire Bracket (RHTC-35L)). I only had to modify it slightly and buy a longer carriage bolt because of the big tire.
Old 08-15-2020, 02:52 PM   #253
jimbosprint
Here's a pic of the bracket
Old 08-16-2020, 10:45 AM   #254
jimbosprint
Yikes! The AC belt stretched a little after a drive across town and it started cutting into the lower radiator hose. I tightened up the belt and pulled the hose down with a zip tie for better clearance. I should probably replace the hose soon. Worth noting that the longer the belt, the closer it gets to that lower radiator hose.
Old 08-16-2020, 11:09 AM   #255
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Attachment 2041140
Attachment 2041141
Yowser!! Not a good scenario. You may need to make some kind of a hose guard...
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-18-2020, 08:54 PM   #256
jimbosprint
Me and my old pickup truck went disc golfing this morning.
Old 08-23-2020, 10:03 PM   #257
jimbosprint
We shall see if this vacuum reservoir helps any with my crummy brakes. I'm too tired to even test drive it around the block tonight.
Old 08-24-2020, 05:48 AM   #258
Ol Blue K20
Looks interesting, let us know how it works.
Dale
Old 08-24-2020, 02:23 PM   #259
jimbosprint
I figured out why the truck would start in any gear and the backup lights didn't work: busted neutral safety switch. Fixed!
Old 08-24-2020, 09:14 PM   #260
jimbosprint
I was skeptical about the vacuum reservoir, and it did not really make any noticeable difference. I think it is an adjustment of the linkage or a bad vacuum booster, but I can't get any shop to work on it.
I hate brakes. Such a simple system, yet I always have problems.
Old 08-24-2020, 09:29 PM   #261
NorCalC20LWB
The brakes on mine are hard as a rock, also tried a vac canister, no difference. Have a new booster on order with Pickmup, will let you know how that works.
NorCalC20LWB is offline   Reply With Quote
Old 08-24-2020, 09:33 PM   #262
Ol Blue K20
That sucks......
Dale
Old 08-24-2020, 10:29 PM   #263
jimbosprint
Maybe that is just the way they are supposed to work? I am definitely interested if a new booster helps yours.
The best way I can describe it: It has functioning power brakes for most of the pedal, but feels like manual brakes at the bottom. It takes a lot of foot to make a complete stop, and there is no way to make a sudden emergency stop. They feel even less safe going downhill. I cannot lock up the tires no matter what.
Old 08-24-2020, 11:43 PM   #264
jimbosprint
I adjusted my headlights tonight. I should have taken a before picture. The passenger side was pointed at the ground instead of my fence. The bulbs don't match so the driver side is a little brighter, but at least they aim the same way now.
Old 08-25-2020, 06:30 AM   #265
Ol Blue K20
Lights are nice and white....
Dale
Old 08-25-2020, 09:14 AM   #266
Low Elco
Seriously, please, i have a similar booster. all you have to do is pop the master off. You'll see a small stub in the booster hole that should have a hex shaft. That's adjustable. It actually pushes the master's shaft. You should feel it make contact juuuuuust before the master bottoms out on the booster, but you should feel it. Look up master cylinder/booster engagement. They make a tool, but I just did it by feel. I had mine way too far engaged, and the fronts would lock themselves in a couple of miles. I got it all set right, much better now.
Low Elco is offline   Reply With Quote
Old 08-25-2020, 09:48 AM   #267
jimbosprint
I did try adjusting that the best I could. However, I don't trust my own work on these brakes so that is definitely worth revisiting.
Old 08-29-2020, 06:57 PM   #268
jimbosprint
My new Summit ram's horn manifolds (2.5" collector) showed up the other day, and the Calyx manifold dressing showed up today. I have an appointment with the exhaust shop on Wednesday for new 2.25" pipes and 18" Magnaflow mufflers.
Old 09-01-2020, 04:31 PM   #269
jimbosprint
The new exhaust manifolds are installed and ready for new pipes and mufflers.
Old 09-01-2020, 05:38 PM   #270
Ol Blue K20
This truck is getting fancy......manifolds look nice
Dale
Old 09-01-2020, 06:48 PM   #271
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
man, what a fun posting to read! You have a really nice truck and good luck on your tasks! I look forward to reading updates and I hope at some point I make Chevy Truck friends like you! LOL
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-04-2020, 03:52 PM   #272
jimbosprint
Just got the truck back from the exhaust shop. It is fairly quiet at idle and has a healthy growl when you give it gas. I'm pleased overall. I asked for the pipes to come out at a 45 (not a 90), but it still looks good.
Old 09-05-2020, 10:25 AM   #273
Ol Blue K20
Looks good, what mufflers did ya use?
Dale
Old 09-05-2020, 10:54 AM   #274
jimbosprint
They are Magnaflows. I need to park somewhere scenic and make a video.
Old 09-05-2020, 11:55 AM   #275
jimbosprint
Video to show the new exhaust: https://youtu.be/PFEGELsYHSk
ochre
