Old 09-06-2020, 03:37 PM   #476
FAKKY
Re: 57 Panel "FAKMLC" build
Originally Posted by joedoh View Post
II built a small stand, just a plate with some legs that I was able to bend into the right shape to move the pedal off the firewall.
Nice - something similar was what I was originally thinking.
How does yours work with regard to mounting to firewall. Also why did you keep it off the firewall ....
Originally I was looking at the brackets teh guys here build on the their C10s .. and was going to mimic .... but so little room now and wondering if it buys me much.
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 09-06-2020, 07:39 PM   #477
joedoh
joedoh's Avatar
I welded the legs to the firewall and bolted the pedal to it.
I had to bring it off the firewall because the pedal hit the floor before a full stroke. I have in the past cut and bent the pedal linkage to achieve the same result but doing that I had to be careful of the welding and grinding heat, it would melt the plastic of the pedal.
Old 09-06-2020, 08:46 PM   #478
MD2020
MD2020's Avatar
Do you have a link to this?????????????
MD2020 is offline   Reply With Quote
Old 09-06-2020, 11:31 PM   #479
dsraven
Much better
Old 09-07-2020, 02:51 PM   #480
FAKKY
Thanks.
Initially I was thinking about something like this ..... but really the position as it stands right now isnt bad ..... I can probably put s small spacer/washer on the backside of the bottom bolt and call it done. Then just paint.
https://67-72chevytrucks.com/vboard/...d.php?t=651123
Old 09-07-2020, 02:51 PM   #481
FAKKY
Here you go
https://spicerparts.com/calculators/...gle-calculator
Old 09-08-2020, 12:56 AM   #482
MD2020
MD2020's Avatar
Old 09-19-2020, 09:58 AM   #483
FAKKY
So quesiton on AC charge.
I started filling my AC. Its a hot day. Probably 85-90 degress and 85% humidity.
AC clutch and AC condensor fan is engaged .... I also put a floor fan in front of car too.
Initially the pressures held around 35/250 with the compressor clutch constantly spinning. As the engine reached operating temperature closer to 200 ..... both sides increased probably to around 50/375.
Chart here => https://www.jamcoautoparts.com/syste...shootingchart/
Not sure what to consider that - probably high pressure a little high ?
Thoughts ?
Old 09-20-2020, 12:17 AM   #484
G&R's57GMC
G&R's57GMC's Avatar
You may be slightly over charged .
Is you evaporator fan on high ?
Is your R.P.M. at 1500 ?
What is your outlet temperature ?
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 09-20-2020, 07:38 AM   #485
FAKKY
No that was at idle .....
That was my initial thought as well (overcharged) ....... but before I work out how Im going to evacuate ..... was wondering if a way to isolate a bit better.
Evap fan is single speed But I did have a floor electric fan pointed at grill/condensor at same time.
Old 09-20-2020, 02:47 PM   #486
FAKKY
Carpet in ....
Not need to finish off a few wires in dash and put in seats .......
Old 09-20-2020, 02:48 PM   #487
FAKKY
Been having problrms with my drivers door closing .....
Removing teh weatherstip and it shuts pretty much fine.
I think its installed correctly.
Anyone know if there is "thinner" version ? Or other ideas/options.
Old 09-25-2020, 08:39 PM   #488
FAKKY
Small "bling" added
Old 10-18-2020, 04:32 PM   #489
FAKKY
Very excited ........ almost ready for paint.
Seatbelts in.
Finished off exhaust.
Finished rear shocks (exhaust is wrapped in ceramic heat matt then wrapped with normal exhaust wrap).
Wrapped exhaust also around transmission.
Finished wiring for electric brake.
New R&P and fitting and NO LEAKS !!
Now just to test AC - get her insured and licenced then start driving for a week oer two then paint.
Old 10-18-2020, 04:33 PM   #490
FAKKY
Old 10-19-2020, 01:39 AM   #491
dsraven
That's awesome. Now, how about some full frontal, sides and rear pics?
Gonna be great to do a few trips now that you're done. Well, you're never done done, just legal. There's always something we find to tweak.
Old 10-24-2020, 08:27 PM   #492
FAKKY
Washed her for first time in 4 years today.
Drove around block - problem with VSS ...... so thats the next deal --- gonna have to speak with the wise one (nova).
Then .... Getting ready for paint ....
Old 10-25-2020, 12:15 AM   #493
dsraven
Nice. Looks like it may be warm inside on a hot day.
Old 10-25-2020, 07:06 AM   #494
FAKKY
AC works pretty good. But yeah - we are on the tail end of summer still .... so temps only in the low 80s versus high 90's ....... so TBD.
Old 12-22-2020, 12:53 PM   #495
FAKKY
Quick question .... going to be replacving all the front door windows and seals.
Paint first so paint gets on old windows - no big deal - but risk damaging paint on replacing ...
or paint after new windows go in .... but just do a good tape job.
thoughts ?
Old 12-22-2020, 02:42 PM   #496
_Ogre
_Ogre's Avatar
my thoughts are to remove all windows and clean up any rust in the window flanges
prime, paint and then install glass and weather seals
tape is cheap and old newspaper is free
shop air compressor timer
Old 12-22-2020, 03:07 PM   #497
FAKKY
Makes sense
Have you reinstalled your own windows ogre ? Mainly the glass not the removal of the tracking itself etc.
I was thinking to follow this video.
https://www.youtube.com/watch?v=AWm_0Rwr5Ng
Old 01-31-2021, 11:49 AM   #498
FAKKY
Took her to home depot for her first "load"
Went well.
Got to quieten the enterior in the back and windows a bit more.
Longer term might look at slightly higher rate leafs in rear and raise her 1-2".
Old 01-31-2021, 01:46 PM   #499
_Ogre
_Ogre's Avatar
i did all my glass, but i have one piece windows
i bought all the stuff to rebuild and keep the wing windows
the hardware under the wings was so rusty it would've required new stuff
great pic first load, i hauled sand, gravel and many tons of bricks in my panel when i was building my first house
i was able to slide an 18 foot steel beam up to the firewall with 4 ft sticking out the back end
it took 4 guys to set it on pillars down the center of the new living room
for temporary load hauling you might want to look at helper air bags
Old 01-31-2021, 08:51 PM   #500
BBPanel
....Got to quieten the enterior in the back and windows a bit more.
What are you thinking about doing re soundproofing? I will need to do the same on my '56 Panel. The windows? Confused.
I asked about a similar issue here but didn't get much back: https://www.trifive.com/threads/pane.../#post-2458660
BBPanel is offline   Reply With Quote
