Old 09-02-2020, 11:13 PM   #251
SkinnyG
SkinnyG's Avatar
Re: SkinnyG's '61 Apache
Ok, so I forgot another patch. But I did get blasted what I wanted to get blasted. Epoxy primer tomorrow. I learned watching "(female-dog)in' Boot Camp" that it's a good idea to have rounded corners on patches, so I thought I'd do that.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 09-02-2020, 11:23 PM   #252
SCOTI
SCOTI's Avatar
Nice!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-03-2020, 12:14 AM   #253
SkinnyG
SkinnyG's Avatar
Super short video:
Old 09-03-2020, 12:37 AM   #254
cwcarpenter98
cwcarpenter98's Avatar
Did the rounded corners work better for you? I'll probably have to try that when I get back on my rust repair if it works better. One day I'll have enough practice to get my patches looking as good as yours
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-03-2020, 01:15 AM   #255
SkinnyG
SkinnyG's Avatar
I am too inexperienced to really notice a difference.
They say 90° corners really mess up the panel, might have been focusing the heat to a point, or the panel shrinking to a pucker, or something. Whatever the reasoning was, it made sense to me at the time. Figured I'd try it.
Old 09-03-2020, 09:24 AM   #256
cwcarpenter98
Ok, that makes some sense. I might have to try that some time. Thanks!
Christian Carpenter
Old 09-04-2020, 09:01 PM   #257
SkinnyG
SkinnyG's Avatar
I patched a section of the Toe board, as it was far more pitted than i wanted. The passenger side inner rocker and cab supports got installed, and now that all that structure is back in and located, the A pillar bottom and kick is being replaced. I was a horrible judge of how long this would take. OMG.
Old 09-05-2020, 12:55 AM   #258
SkinnyG
SkinnyG's Avatar
Handy tip - use the appropriate sized end mill in a hand drill (lightly) to clean out your epoxy primer or weld-through primer prior to plug welding.
Old 09-05-2020, 09:48 PM   #259
SkinnyG
SkinnyG's Avatar
Handy tip - use sheet metal screws to suck the cab supports up to the floor for welding, then just plug weld the holes.
Driver's side rocker and floor done, and A-pillar bottoms are epoxy primered and drying, ready for welding tomorrow.
This side was just as annoying to do as the other side. I am losing my patience too easily.
Old 09-06-2020, 12:14 AM   #260
cwcarpenter98
I like that idea about the screws. I'll have to use it when I finally get to that point on my truck. The progress is looking great!
Christian Carpenter
Old 09-06-2020, 08:33 PM   #261
SkinnyG
SkinnyG's Avatar
I hung the door to fit the outer rocker, which (after some significant adjustment) fit with gargantuan door gaps. The door already had the hinges as high as they would go, and the guide on the door also adjusted as high as it could go, and the gaps are freaking drunk. The build quality of these trucks betrays the golden age of no seatbelts, and bottle openers on the dashboard.
Since it appears that the door bottoms in and out should be replaced, I may "adjust" the gap at that time. Or ignore it completely.
Old 09-07-2020, 08:19 PM   #262
SkinnyG
SkinnyG's Avatar
Oh My Gosh - the body panel gods must be smiling. The back of this rocker panel fit perfectly, the front only needed two slits.
And two coats of epoxy primer, and that's it for my summer. Back to work tomorrow. My projects usually stall for close to two months at the start of the school year because work sucks all my energy away.
Old 09-08-2020, 02:33 PM   #263
The Rocknrod
Moderator
The Rocknrod's Avatar
Boy that makes things easier.
Old 09-08-2020, 07:05 PM   #264
SCOTI
SCOTI's Avatar
Good looking progress.
Good luck w/the school year start-up!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-08-2020, 08:07 PM   #265
Corts60
Just here to tinker
Corts60's Avatar
Excellent fabbing! Well done.
Old 09-12-2020, 09:02 PM   #266
SkinnyG
SkinnyG's Avatar
Rockers are welded in, and I welded a "tab" I bent back for the rear cab supports.
Hopefully, cab corners tomorrow.
Old 09-13-2020, 12:39 AM   #267
aotte1
Thanks for all the progress pictures, looking good.
aotte1 is offline   Reply With Quote
Old 09-13-2020, 09:09 PM   #268
SkinnyG
SkinnyG's Avatar
Both cab corners are fitted. They both needed tweaking as the curve didn't match, and the beading at the bottom didn't match. Good think I have hammers.
The passenger cab corner was actually very solid. But I cut as little of it as I figured I could get away with, just to make sure that ALL the rust in the nooks and crannies are gone. I want to do my best to make this repair last as long as possible.
Sprayed epoxy over the rockers, and in and on the cab corners in preparation for welding whenever I get to them.
Oh, also filled the hole in the cowl.
Old 09-13-2020, 09:38 PM   #269
cwcarpenter98
Lookin' good as always! What are you using to spray the epoxy?
Christian Carpenter
Old 09-13-2020, 09:43 PM   #270
SkinnyG
SkinnyG's Avatar
I'm actually using a wee touch-up HVLP gun from Princess Auto (the CDN equivalent of Harbor Freight). It sprays REALLY nice for me, and the size really minimizes overspray.
When I am ready to do the whole body, I will use one of my bigger guns for sure.
Old 09-13-2020, 09:46 PM   #271
SkinnyG
SkinnyG's Avatar
I guess, at this point, I could spray some Orange, and then a light spray of green lacquer, and rock the patina....
It would save me HOURS of bodywork.
Old 09-13-2020, 09:46 PM   #272
cwcarpenter98
Ok, thanks. I'll have to look into getting a spray gun setup just for some epoxy primer since it seems that it's not available in a rattle can
Christian Carpenter
Old 09-13-2020, 11:38 PM   #273
SkinnyG
SkinnyG's Avatar
Eastwood sells 2K primer in a spray bomb, but it gets pricey real fast.
Old 09-14-2020, 10:29 AM   #274
SCOTI
SCOTI's Avatar
No complaints here. The sooner it's done how you want it, the sooner you're enjoying the fruits of your labor.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-14-2020, 10:57 AM   #275
cwcarpenter98
Ok, thanks. I had not found that product in my prior searches. My reasoning behind using a rattle can is to lay down some epoxy primer instead of regular primer on the areas where I patch since I'm not going to be doing a full paint job any time soon. In my case, I'm not sure which is better: a regular primer or epoxy primer
Christian Carpenter
