Old 09-20-2020, 07:15 AM   #1
BlouDon
BlouDon's Avatar
SBC 350 Aches and pains
Starts well.
idles well.
drives well on light throttle.
But from about 30% throttle, she starts to "backfire" - but through exhaust,left side only. The more throttle, the more backfiring.
This is what I found on #3exh when I removed the heads.
Best regards, Philip
Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp )
Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e
Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12
BlouDon is offline   Reply With Quote
Old 09-20-2020, 09:12 AM   #2
jjzepplin
jjzepplin's Avatar
Re: SBC 350 Aches and pains
Ouch!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-20-2020, 10:42 AM   #3
truckster
truckster's Avatar
You might need a new valve there...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-20-2020, 10:52 AM   #4
BlouDon
BlouDon's Avatar
Yep, having tge heads "done", including new valve.
Amazingly, no visible damage to the cast iron head
Old 09-20-2020, 11:50 AM   #5
kwmech
Machine shop should still install a seat if not all of them
Old 09-20-2020, 12:03 PM   #6
BlouDon
BlouDon's Avatar
I've been wondering if these heads are ready for unleaded...
How would I know?
Old 09-20-2020, 03:03 PM   #7
vince1
As far as I know if they don't have hardened seats such as Stellite then they are old school and not so good for unleaded gas, but maybe I don't know very much. I could be just guessing on this one.
vince1 is offline   Reply With Quote
Old 09-20-2020, 08:03 PM   #8
AcampoDave
AcampoDave's Avatar
I wonder why it burned in one spot like that.
AcampoDave is offline   Reply With Quote
Old 09-20-2020, 08:25 PM   #9
truckster
truckster's Avatar
Probably a metallurgy failure. One weak spot that failed and then the exhaust gases kept the erosion going.
Old 09-21-2020, 03:31 AM   #10
BlouDon
BlouDon's Avatar
Is it not normal to burn in one spot?
Old 09-21-2020, 08:38 AM   #11
geezer#99
geezer#99's Avatar
Looks more like something got stuck in there at one time.
What does the piston on that cylinder look like?
geezer#99 is online now   Reply With Quote
Old 09-21-2020, 08:48 AM   #12
BlouDon
BlouDon's Avatar
Nothing on that piston to set it apart from the others.
Not at home at present, so I can't post a pic.
Old 09-21-2020, 01:47 PM   #13
Tom
driving is in my blood
Tom's Avatar
They went to hardened seats when they changed away from leaded fuel.
This is a valve problem not a seat problem.
Old 09-25-2020, 09:42 PM   #14
gvw5400
gvw5400's Avatar
At least on US spec. engines, In 1971 GM dropped the compression ratio from 9.0-1
to 8.0-1 and started " Induction hardening" the valve seats in the heads to allow the use of
unleaded gasoline. Glad you are able to repair your engine backfire issue Philip!
All The Best
Dirk
gvw5400 is offline   Reply With Quote
Old 10-04-2020, 02:38 PM   #15
BlouDon
BlouDon's Avatar
Just an update on my woes:
Valve replaced, heads serviced, reinstalled.
Starts well.
Idles well
Drives well on light throttle.
YEP, Same as per post #1!!
Inspected HT wires and found a bad one. Replaced it.
HAPPY CHEVY!!
Experiences like this keeps me humble...
Old 10-04-2020, 03:39 PM   #16
truckster
truckster's Avatar
Starts well.
Idles well
HAPPY CHEVY!!
It's frustrating, but at least you know the work you had done was necessary anyway.
I'm glad you got it figured out and running right.
Old 10-04-2020, 03:53 PM   #17
BlouDon
BlouDon's Avatar
I shudder to think how long I would have driven with that valve had I found the bad HT wire first...
So yes, I'm not complaining but it was most disappointing after all that effort and money to have the same symptoms.
Old 10-04-2020, 05:24 PM   #18
hjewell2
hjewell2's Avatar
HT wire ??
hjewell2 is offline   Reply With Quote
Old 10-04-2020, 06:44 PM   #19
burnin oil
Guessing plug wire. Don is from another continent.
burnin oil is offline   Reply With Quote
Old 10-04-2020, 08:01 PM   #20
truckster
truckster's Avatar
Originally Posted by hjewell2 View Post
HT wire ??
High tension - meaning high voltage.
Old 10-05-2020, 01:06 AM   #21
BlouDon
BlouDon's Avatar
HT wire ??
HT wire = high tension = spark plug wire.
Old 10-05-2020, 07:11 AM   #22
4u2nv
Someone educate me on how to check a spark plug wire to see if it's failing
4u2nv is offline   Reply With Quote
Old 10-05-2020, 08:03 AM   #23
BlouDon
BlouDon's Avatar
Here are a few (not a comprehensive list):
1) Running the engine in a dark environment and checking around the engine bay for blue-ish flashes - indication of spark escaping from the wires and jumping to "ground". NOTE: This may only happen at heavier engine loads - as was happening in my case!! Blipping the throttle rather deep may cause brief heavy load periods;
2) Pulling a spark wire off the spark plug and nothing changes NOTE: This could also result from plug or dissy issues;
3) Measure it with a multimeter. For most modern cables you should get a reading in the region of 8000 - 12000 Ohm (or thereabouts)
4) Visual inspection of the cables: This is what I found on my engine:
Old 10-06-2020, 11:49 PM   #24
burnin oil
Different plug wire types have different ohm readings. Best bet is to compare 2 similar sized wires of the set and the ohms should be similar. When you look at aftermarket plug wire they rate it in ohms per foot.
Old 10-09-2020, 01:33 AM   #25
BigRandy
BigRandy's Avatar
I found this to be very important. I had a random misfire that I chased for days - replaced cap, rotor, plugs looked for arcing and saw none so I kept the same wires. They looked like they could be wiped off and put back in the box. Checked plug gap again on new plugs, checked cap for cracks and found nothing out of the norm.
Pulled out the multimeter and checked resistance in the wires looking for 12K ohms per foot and found #1 wire ranged from 8 to 24K ohms depending on how I held it. Swapped it out and haven't had a miss since.
Bottom line: VERIFY.
Repairing and driving old trucks is an analog experience. No computers or sensors and they can be fixed with basic hand tools
BigRandy is offline   Reply With Quote
