09-03-2020, 10:49 AM | #1 |
63 gmc windshield gasket
I had a windshield installed and the top corners are not sealing right. I bought the gasket from brothers, I dont remember who made it. Is anyone else having this issue?
09-03-2020, 11:15 AM | #2 |
It's Better With Nitro
Re: 63 gmc windshield gasket
If it becomes an issue that is untenable and need to replace it, I would recommend going with a Precision Replacement seal. Mine fit perfectly and installed with ease.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
09-03-2020, 04:09 PM | #3 |
I was going to recommend the same brand. I got steel rubber products and they are way to stiff
09-03-2020, 06:25 PM | #4 |
Just here to tinker
https://67-72chevytrucks.com/vboard/...d.php?t=568864
I made this thread awhile ago about these year windshields....
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-03-2020, 06:28 PM | #5 |
09-03-2020, 10:24 PM | #6 |
Why, do you? I only used foaming dish soap to ease the install of my windshield and seal.
09-04-2020, 09:40 AM | #7 |
Yep, been there done that, had the glass guy come back and remove the inferior gasket and install a Precision.
09-04-2020, 12:40 PM | #8 | |
In your photo it looks like the gasket is painted the same color as the truck below the trim. My gasket seems like it is bulkier than yours either that or your window trim is wider. |
09-04-2020, 12:44 PM | #9 |
It looks like there is white paint on it.
09-05-2020, 08:28 AM | #10 |
forest b i believe thats the paint break line you see..he has the wide trim from 60-61 custom cab which covers a good bit of the rubber.
09-05-2020, 11:10 AM | #11 |
Fancy. I didn’t know there are two types
09-05-2020, 11:12 AM | #12 |
09-05-2020, 11:14 AM | #13 |
Moderator
Is that the same glass you took out to begin with?
09-07-2020, 07:40 AM | #14 |
Had to get new glass. It is pilkington glass
Posted via Mobile Device |
09-10-2020, 03:26 PM | #15 |
From the pictures either the glass might be small, or the glass is not fully seated into the pinchweld. When the seal is fully seated the outer fin will sit out on the body. If your seal is not sitting flush against the cab on the inside in the same spots where the issues are on the outside of the cab the seal is not installed correctly.
09-12-2020, 12:55 PM | #16 |
I had a professional install it so i assume it is in correctly
09-21-2020, 07:36 PM | #17 |
I need to replace my windshield in the 63, and I am not sure if I want to tackle it on my own. If I crack the windshield, I would be soooo pissed.
I'm in Southern California, so I am hoping I can find someone I trust to do this. I would only go with someone that will insure me it will not crack.
1963 C20, small window, long bed 292, 4-speed |
09-21-2020, 09:17 PM | #18 |
I could try to get the info for the guy that installed mine. But he is in north Hollywood so I am not sure if he will go all the way down to Orange County
09-21-2020, 09:35 PM | #19 |
Yeah, that’s a long drive.
09-22-2020, 09:30 AM | #20 |
Moderator
Man if I lived around Batavia and Collins area I'd be fat for getting stuff done on my Truck. I drove through there when I visited the Truck Shop and was impressed with the custom car shops in that area. You guys have everything.
09-22-2020, 11:11 AM | #21 |
If you are referring to Asshat's post, he is in Orange County CA not NY. Then yes driving for North Hollywood CA to Orange County NY would be a vary long drive for a glass man
09-22-2020, 11:30 AM | #22 |
I would appreciate the info anyways, might be worth talking to him.
09-22-2020, 11:33 AM | #23 |
Yes, there are quite a few shops around there. I got my seat re-upholstered in Santa Ana for $450. However, I prefer to do most of the repairs myself, I’m not rich. Some of those shops charge a ton of money for simple repairs.
09-22-2020, 11:43 AM | #24 |
09-22-2020, 11:44 AM | #25 |
