09-22-2020, 07:05 PM | #51 |
Junior Member
Re: Should I cut this truck ?
My initial opinion is YES! ABSOLUTELY! BUT.... now that I see the tool box and leaf rear, that changes my mind. Leave it. A shortened truck should be on bags or at least a static drop and on a leaf rear, bags are just not possible. Also, shortening the bedsides gets sketch with the tool box.
LEAVE IT.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Gold White Fleetsides/Saddle |
09-22-2020, 07:49 PM | #52 |
67-72 parts collector,…
metaloxfab on Instagram is one of the best at shortening bedsides.
Even the ones with tool box doors,...
09-22-2020, 07:51 PM | #53 |
Junior Member
OK now that's pretty cool.
09-22-2020, 07:56 PM | #54 |
And no seams in the shortened door,...
09-22-2020, 08:45 PM | #55 |
I started out with nothing - and I still have most of it |
09-22-2020, 08:48 PM | #56 |
You can't shorten it, your SPID would then be incorrect!
Do what you'd like Eric, that's the only real answer - and you can't go wrong. And I do understand the draw - but you already know which side of the fence I fall on |
09-22-2020, 09:52 PM | #57 |
I would make a k20 out of it add some cab lights and call it done
09-22-2020, 10:06 PM | #58 |
Leave it as it is!
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
09-22-2020, 10:23 PM | #59 |
All about them K’s
That’s definitely nice work shortening those bed sides. I don’t think I’d have the balls to cut up an extremely hard to find rust free tool box door like that. Mine is rust free as well and I haven’t seen another one in similar condition over the last several years. That said it is pretty cool that they were able to keep the tool box on it. Doesn’t change my opinion though. I still wouldn’t shorten Chevylands black super.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
09-23-2020, 07:58 AM | #60 |
I don't see the tool & stowage compartment as a factor. Pull the bed and put on a shortbed, used or new from parts. I'd be fine with leaving it long, but I opened my mind to him shortening once I saw the frame has already been altered with a c-notch. And as far as lowering goes, it's axle flip ready for that. You all have to remember, this man has variety already, and it looks like he's considering expanding to have a ride to fit in with his truck buddies he hangs with. Considering all the elements I can see where this contemplation is coming from. Remember, this is a "like 'em stock" guy. Nothing wrong with expanding that to "like 'em all" or "one of each".
09-23-2020, 11:40 AM | #61 |
At the body shop.
Cut it.
A cut down longbed is more desirable than a longbed. A purist may disagree. But the market says otherwise.
" That didnt make it any newer " " Dont antique the equipment " |
09-23-2020, 01:46 PM | #62 |
A short bed catches my eye when I see them. They are more rare because they could not be worked as much and farmers and such wanted trucks to haul things...BUT I can not condone cutting that one down! Frame damage ,as mentioned, no bed or rotted out bed, a bunch of franken parts...make a short bed, but don't take a long bed's life. At least go find a short box and sell the long one.
It's your truck, honestly, do what pleases you!
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
09-23-2020, 01:53 PM | #63 |
BlahBlahBlah
Its your truck do what you want. I would have zero trouble cutting it if I wanted a short bed and thats what I had to work with. Like you said the stigma of selling a cut down long bed seems to have waned when it comes to someone buying one. Maybe not some of these guys on the board, but generally =)
09-23-2020, 02:55 PM | #64 |
Chop it , And by doing that it makes the "REAL" short beds worth more . It's only made it almost 50 years without someone hacking away at it . You may as well drop it on the ground with air bags and raise the bed floor and throw an LS in it at the same time with a few computers to make it run and don't forget to add all the high $ stereo equipment into the newly chopped dash . Don't forget at least 4 cup holders and enough Led lights that it can be seen from the space shuttle and after all that $ dumped into it leave the "patina paint"
It's your truck do whatever makes you happy with it .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-23-2020, 03:00 PM | #65 |
I don't always agree with Grumpy - but when I do, it's posts like that!
09-23-2020, 03:48 PM | #66 |
laying low
With it's C notch it's already been "hacked" so it was well on it's way to being lowered and what ever else anyway. It was violated!
09-23-2020, 05:37 PM | #67 |
09-23-2020, 05:45 PM | #68 |
laying low
Nice.
09-23-2020, 06:00 PM | #69 |
At the body shop.
09-23-2020, 06:40 PM | #70 |
Friend of mine has and put a Duromax in it
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
09-23-2020, 07:31 PM | #71 |
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
09-23-2020, 10:56 PM | #72 |
It seems to me like it would be a great candidate for a new No Limit or Roadster Shop chassis, either long or short! Get it down in the weeds and do it right if the $$$ is not a concern.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
09-24-2020, 08:07 AM | #73 | |
As far as all that other jabber... You feelin' alright?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-24-2020 at 08:13 AM. |
09-25-2020, 05:21 PM | #74 |
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
09-25-2020, 08:21 PM | #75 |
