09-22-2020, 10:30 PM | #1 |
Do bulb sockets go bad (short out)?
Truck sat a while during the LS swap. Now I have all my lights except taillights and marker lights. Using the power probe on the rear section of the harness (disconnected from the main) I get a dead short on the taillight (brown) wire. I see no damage anywhere (truck is very clean). Just asking before I start cutting and replacing.
09-22-2020, 11:04 PM | #2 |
Re: Do bulb sockets go bad (short out)?
What is a power probe? What are the steps you followed to test?
09-23-2020, 05:26 AM | #3 |
trailer wiring or butchered remains hidden back there??
I started out with nothing - and I still have most of it |
09-23-2020, 12:19 PM | #4 | |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
09-23-2020, 12:46 PM | #5 |
I'm gonna guess brake light switch. Did you upgrade the brake light switch for the ls swap to the f body switch like most do? When i did mine i didn't wire it correctly and had a similar issue.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
09-24-2020, 10:01 AM | #6 |
My initial description may have been lacking. I'll try to clarify.
The rear lighting harness is disconnected at the factory plug just before the rear bumper. When I apply power to the other 3 wires in the plug, the associated light comes on. However, when I apply power to the dark brown taillight wire, it trips the breaker on my power probe (when the harness was plugged in, it blew the fuse). There is no visible damage to the harness. The trailer lighting was a factory-style plug and play setup (no spliced wires) but I removed it from the circuit to eliminate it as a possible problem. This is a power probe. One of the most useful tools I ever bought. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
