09-28-2020, 08:37 PM | #1 |
Gears front /back
Building my k5 rear. I am putting in 3.73 in the rear. Question is do I put the same gear type in the front?? Since I am putting 3.73 in the rear.
thank you, John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
09-28-2020, 08:49 PM | #2 |
Re: Gears front /back
The only time the front and rear should be mismatched, is for some extreme mud-racing situations. I think they usually overdrive the front axle a little, to keep the vehicle tracking straight under full-power runs in deep mud.
For anything else, you definitely want them to match. If you're trying to spread out the cost, you can leave the old gears in the front for now, but you should remove the front driveshaft to avoid any risk of engaging the front axle.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-29-2020, 10:04 AM | #3 |
i have a question for the o.p.
what size tires ? and trans and you planning ? doing all the work i hate to see you do it for the wrong ratio .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-29-2020, 10:42 AM | #4 | |
I'm building the truck in my signature with 4.10 gears and 33" tires. I think this combo(engine/trans/gears/tires/truck-weight/intended-usage) will work well together. I expect to do a bit of gooseneck towing with this truck. I doubt I'll use overdrive at all when towing, unless I reach 65+ mph. There's a good chance as well, that I'll be skipping first gear when driving empty.
09-29-2020, 02:52 PM | #5 |
My IH build with the LS/nv4500 and 33in tires got a set of 4.56s..
My C30 with LS/nv4500 and 31in tires has a set of 4.10s.. Kipps..I'm betting you use 1st more than you think..
09-29-2020, 04:17 PM | #6 | |
What engines are in your trucks? 6.0, turbo-4.8, etc? For my build, would you have recommended 4.10 or 4.56, considering my VVT 5.3, nv4500, 33" tires, and combination of run-around usage and heavy stock-trailer towing? Part of my reasoning was that I'm largely duplicating what GM was building in the early 2000's. Same gearing, similar engine, same transmission, etc.
09-29-2020, 06:24 PM | #7 |
Yeah kipps..your setup will probably be just fine...i had a 99 z71,5.3/4l60 that had 31s and 3 73s..i used to tow with it and it did just fine..
1st in a nv4500 isnt real low..not like a sm465 anyway...my C30 has a stock LQ9 6.0 with headers and a dyno tune..I regularly pull 10k loads with it...it will cruise all day at 75-80 mph with this setup...I love the way it works...at 65mph its turning just over 2000rpm...i really like the way it is.. The IH hasn't been driven but I tried to duplicate my C30 setup on it...only diff is it is a 5.3...but with the little taller tire I think the 4,56s will be fine..
09-30-2020, 06:37 PM | #8 |
Thanks everyone for chiming in. To answer The size of the tires, they are 31 x 10.5. As far as the trans, I do not really know much about transmissions except it is the standard type that you would fine in a k5 blazer. Again thanks, John
09-30-2020, 07:17 PM | #9 |
What yr model blazer...I'm guessing maybe a t350 trans...
09-30-2020, 10:01 PM | #10 |
Its a 1979 BLAZER frame with a truck cab on it. I think it is a th350.
10-01-2020, 12:49 AM | #11 |
If it's a t350 itll have a final ratio of 1:0
So with 3.73s ,and 31in tires , and a 1.0 trans, you'll be turning 2628 rpm at 65mph.. http://www.csgnetwork.com/multirpmcalc.html
10-01-2020, 06:50 AM | #12 |
Those rpms won't be bad at all for a LS engine. They're a tad high for a SBC.
Here's my favorite gear ratio calculator -- http://www.grimmjeeper.com/gears.html
10-01-2020, 07:30 AM | #13 |
I see what you guys are running here and mine is a 87 c10 4x4 350,350 and 342 rear gears and at 50 miles per hour mine is tacking at 3000 .
WHY ????? And she is a pig on gas. |
10-01-2020, 08:14 AM | #14 |
@Big Blue, is that frame painted silver, or did you by any chance galvanize the frame?
10-01-2020, 08:16 AM | #15 |
You're right, the 3000 rpm doesn't make sense. What tire size? Is your convertor locking up or not? Have you double checked the tach and speedo accuracy? Check the tach with a timing light, and check the speedo with a phone GPS.
10-01-2020, 09:00 AM | #16 |
That don't make since, it sounds like your truck is in second gear. What size tire do you have?
It only has original paint once Last edited by Mathew21; 10-01-2020 at 07:09 PM. |
10-01-2020, 10:36 AM | #17 |
4u2...something sure ain't right...I just guessed at what size tire you might have...and like Matthew stated..in 2nd gear would be close to 3k rpm...
Like asked ..what size tire are you running?...and double check rpm and mph...
10-01-2020, 02:15 PM | #18 |
thanks kipps, Painted silver. though I'd be different.
John
10-01-2020, 03:08 PM | #19 |
Thought I'd ask. I'm seriously considering hot-dipping a frame. I was quoted $450 to dip a sandblasted full-size truck frame. The Land Rover guys do it frequently, due to the bad rust problems they have with their frames. As I see it, hot-dipping is about the same price as using a proper three-stage chassis paint from Eastwood. It should be much better protection.
10-01-2020, 05:23 PM | #20 |
4u2nv your in 2nd gear via the calculator at 50mph and 3k rpm .
you have the vacuum modulator hooked up ? or maybe another problem . can you start off and count 2 up shifts . first is a given then bump 1 = 2nd and bump 2 = 3rd .
10-01-2020, 09:10 PM | #21 |
35"s for tires, i think i should check the converter,tach and speedo are good
10-01-2020, 09:13 PM | #22 |
10-01-2020, 11:21 PM | #23 |
4u2...you've got some serious issues going on...with the numbers you stated you should be turning 1642rpm...
are you sure your tach is right?...I know some older tachs had dip switches for 4,6, or 8 cyl
10-02-2020, 07:35 AM | #24 | |
You can tell going down the highway that it is reving that high . Truck shifts good , has all kinds of throttle response . At 65 mph it tachs at 4000 . I'm puzzled . |
10-02-2020, 09:24 AM | #25 |
Your numbers do line up perfectly with it staying in second gear.
Try putting the truck on a lift, and run it up to speed. With no load, see if the tach and speedo act the same as they do while driving. Also, while still on the lift, use a timing light on the engine and the driveshaft. The two should be exactly the same speed if the converter is locking in on 3rd gear.
