10-01-2020, 09:48 AM | #23 |
Re: 4L60E Trans only shifts 2 and 3
It is original. That depends on which pin is the right pin. On pin E I have less than a volt. Pin N I have 10.6 v. Dayj is saying pin E is the correct pin, in which case there's less than a volt there. Should I try to check it with the engine running and see how many volts are there?
Eric 70 CST10 long bed in pieces also factory air and cruise(the project) 18 Silverado crew cab 5.3 4x4 My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166 |
