Old 09-28-2020, 12:41 AM   #226
sginphx
Re: My 56 build
Looks amazing Jason!! All that hard work is paying off and it's going to be an awesome ride!
sginphx is offline   Reply With Quote
Old 09-30-2020, 12:09 AM   #227
Jason 56
Re: My 56 build
Thanks SG, your truck has been inspirational to me! Can’t wait to see it done!
I finished getting everything in primer today. Slow to cure... was only 50 here today. Now to concentrate on the drive train! Transmission mount is next.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 10-03-2020, 12:15 AM   #228
Jason 56
Re: My 56 build
Finished the transmission mount and reassembled some of the front end. I was eager to see how the frame adjustment turned out. It was exactly what was needed. Now the front of the frame isn’t so low. Sure is nice to see it all one color again!
Old 10-03-2020, 09:18 AM   #229
reaper71
reaper71's Avatar
Re: My 56 build
looking good Jason!
Mark
reaper71 is offline   Reply With Quote
Old 10-04-2020, 12:08 AM   #230
sginphx
Re: My 56 build
Firewall looks great and LOVE your inner fenderwells! Look similar to mine. Keep up the great work!
Old 10-04-2020, 07:55 AM   #231
slammed57
slammed57's Avatar
Re: My 56 build
looks fantastic . I did the same as you for the inner fenders. Iam not sure how low your truck will sit ,or the size of wheels, but check the front wheel clearance /travel to the fenders if you can. Iam on air ride and it was real close to rubbing when aired out and I had to modify it.....come to think about it, just about everything I had to do to to my truck had to be modified, even some of the bolt on guaranteed to fit parts! lol
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 10-12-2020, 06:54 PM   #232
my56chevytruck
my56chevytruck's Avatar
Re: My 56 build
super nice work Jason. it's impressive to see the detail you've put into your work.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 10-12-2020, 11:17 PM   #233
Jason 56
Re: My 56 build
Good call. I’m planning on pulling the front springs and checking full travel. I’m pretty sure it should be ok with a static suspension... I hope
Old 10-26-2020, 09:35 PM   #234
sginphx
Re: My 56 build
Jason you are doing such a great job! Hope you're enjoying at much as we are watching! Keep it up...
Old 10-28-2020, 10:15 PM   #235
Kevin_C
Re: My 56 build
Looking great. I just picked up an Gen V LT1 & 8l90 for mine.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 10-29-2020, 12:19 PM   #236
MDPotter
MDPotter's Avatar
Re: My 56 build
Where did you guys find your Gen V powertrains? I've looked on eBay and I don't find that many engine/trans combos. I'd also be interested in getting the fans, radiator, and intake.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 10-29-2020, 12:53 PM   #237
Kevin_C
Re: My 56 build
Facebook market place and craigslist. There is a group on FB that a lot get listed.
"GM Gen V LT Swap and Mods" I lost out on a couple L83's with 6 speeds but ended up finding the LT1 local through FB market place.
Old 10-29-2020, 12:57 PM   #238
MDPotter
MDPotter's Avatar
Re: My 56 build
Good to know, thanks! I've seen a couple listed locally on FB but one was basically brand new so they wanted a lot for it and the other was a mismatched engine/trans and I don't want to deal with that as these engines and trans don't seem to match up as easy as Gen 3/4. I'm also particular in what I'm looking for - 2014-2016 as it seems like the 2016.5+ require expensive ECM work to get them running.
Old 10-30-2020, 12:51 AM   #239
Jason 56
Re: My 56 build
That’s cool. I haven’t found mine difficult to install. I’ll see how it goes as I slowly piece everything else together, then try to start it.
Old 11-14-2020, 10:50 AM   #240
Last_Paladin
Re: My 56 build
How much room behind the HPFP and in front of the throttle body do you have?
Playing around with a model of Kevin's truck
Last_Paladin is offline   Reply With Quote
Old 11-15-2020, 10:42 PM   #241
Jason 56
Re: My 56 build
My firewall clearance is about 3” and I have 7” of clearance between the dampener and core support. My firewall/blister is completely custom so it will be different from stock.
Old 11-16-2020, 03:36 PM   #242
Last_Paladin
Re: My 56 build
Thanks.
We don't want a dog house in Kevin's build, so trying to avoid that.
Old 02-12-2021, 11:16 PM   #243
Jason 56
Re: My 56 build
It’s been a while since I’ve posted. I’ve been putting off a lot of home projects since I started my truck. I have most of them done now. So back to the truck! Fuel pump is mounted in the tank. Had to modify the pump height and the fuel level arm to work with my tank.
Old 02-12-2021, 11:30 PM   #244
Jason 56
Re: My 56 build
I spent a whole weekend installing new door seals and setting latch strikers. Wow was that fun Lots of adjusting and it turned out pretty good! The custom latch setup appears to work well. So... I’ve decided to move on to the interior. Here’s a shot of the drivers door card and kick panel. Not sure yet if fiberglass is in my future... maybe. Also a sketch I did for ideas.
Old 02-14-2021, 09:46 PM   #245
Jason 56
Re: My 56 build
So I used some MDF and made door handles. So far it looks pretty good. Just needs some filler to finish them. The auxiliary door pulls from the corvette should blend nicely.
Old 02-15-2021, 11:09 PM   #246
Dan in Pasadena
Dan in Pasadena's Avatar
Re: My 56 build
Impressive work, Jason!
I hope you don't mind if I make a few comments. Shouldn't you put some sort of screen across the louvers in the electronics box to ward off water getting in there if you drive through a puddle? The electronics box is a smart idea and wonder if you could put the electronics on a sort of shelf on drawer slides so you can pull it out when you want to service something in there.
Last, too late now but did you consider the old wheel barrow trick instead of all the metal work on your firewall? It really came out great but I imagine that was a LOT of work a wheel barrow donor would have avoided. But again, all nice work! Can't wait to see this build finished.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-16-2021, 08:02 AM   #247
6DoF
6DoF's Avatar
Re: My 56 build
love it! props on your patients and attention to detail.
6DoF is offline   Reply With Quote
Old 02-16-2021, 09:17 AM   #248
57FleetsideC4
Re: My 56 build
Times 2 on that. Very nice detailed work. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 02-16-2021, 11:15 PM   #249
Jason 56
Re: My 56 build
I’ll see if it’s a problem when I start running it. I directed all the louvers away from directional tire spray, but who knows. I’m not worried about any of the electronics in there because everything is water resistant and factory mounted in similar locations/conditions
Last, too late now but did you consider the old wheel barrow trick instead of all the metal work on your firewall? It really came out great but I imagine that was a LOT of work a wheel barrow donor would have avoided. But again, all nice work! Can't wait to see this build finished.[/QUOTE]
I actually bought a wheelbarrow and moved it around mr garage for a year. When it came time to make the blister... I didn’t like the shape. So I grabbed the hammer.
Old 02-16-2021, 11:16 PM   #250
Jason 56
Re: My 56 build
Thanks guys!
