![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
No race for front outter wheel bearings??
1971 GMC 3/4 disk
Just wanna make sure I'm not missing anything. I know the inner wheel bearings have a race. The outter bearings doesn't, right?? I'm asking 'cause I'm shopping for new outter wheel bearings and I find them with and w/o the race. I don't remember anything besides the tapered outter wheel bearing falling out after removing the rotor. Thanks. |
Who Changed This?
Re: No race for front outter wheel bearings??
There is a press-in race for the outers, same as the inners, but smaller, of course.
![]() Join Date: Nov 2013
They are two piece bearings...called cup and cone
the inner and outer race (cup) is pressed into the hub....the cone is loose and captured by the spindle nut don't over tighten them when installing.... snug down till you feel a little turning resistance them back off about 2-3 slots in the castillated nut
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() Last edited by A1971Blazer; 10-05-2020 at 10:58 AM. |
You won't notice the race typically as it should be covered in a good layer of grease. If you wipe around with some rags you will see the race is pressed in just like the inner bearing race but with no seal other than the dust cap.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
![]() Join Date: Jan 2001
The bearing will fall out, but the race is pressed in.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
68 C10 Longbed
![]() Join Date: Sep 2006
Inner and outers both have races. Always change races when replacing with new bearings.
Agree. And every new rotor I have ever bought had races installed but I have never used them. I always use the race that came with the new bearing. I like to use those (or the old race) as install tools for the new ones. I take a cutoff wheel and cut it through. Then flip that over small edge to small edge and you have a nice tool to install the new race evenly. If it is driven/pressed into the bore some it is easy to remove since it is not solid. There are tools to install races and seals but if you don't have those, this method is free.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
