10-07-2020, 09:45 AM | #1 |
Re: Aluminum intake and vacuum fusion snafu - now what?
That plastic is actually phenolic resin. Same stuff used for heat spacers on eddy carbs.
You can buy separate thread chasers. No need for a complete set unless you feel the need for more tools. Are you gonna pull the intake to fix those threads? |
10-07-2020, 10:48 AM | #2 | ||||
https://www.harborfreight.com/6-piec...BoC0iQQAvD_BwE Id need a 5/16 and a 3/8 UNC chaser though as well to hit all of them. Is chasing a better idea than tapping? Ugh, looks like it unless I can rig up a catch block under and vacuum out the shavings. Im attaching a screen grab of the specs, the installation instructions I got in the box doesnt have it. In fact the water pump inlet isnt listed or the thermostat housing so I need to look those up. |
