10-12-2020, 08:09 AM | #1551 |
Re: What did you do to your truck today.The 3rd chapter
Got all the parking brake hardware reinstalled and adjusted. Started installing my brake lines. Got the ones that run along the differential, rear flex line, and the long one from the flex line to the front installed. Now gotta tackle getting everything ran along the front crossmember and up to the master cylinder.
Wife is going out of town with her sister this Friday and Saturday so I predict some serious shop time in my future.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
10-12-2020, 03:20 PM | #1552 |
Raining and cold . But my new cab bushings came for the stepside so now I can start fitment of the nose. Went with regular rubber.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
10-13-2020, 08:41 PM | #1553 |
Finally put a sport bumper on it.
10-13-2020, 08:48 PM | #1554 |
It looks nice with the original painted wheels and hub caps!!!!
10-15-2020, 03:17 PM | #1555 | |
Why only for shows?
10-15-2020, 03:18 PM | #1556 |
Doing the cab mounts today . It needed them
10-15-2020, 03:39 PM | #1557 | |
Only for shows mostly because everyone keeps telling me they are dangerous even though they all came with them back in the day. I know they are dangerous to mount, but I think once they are on they are ok. But also to keep them in good shape and since I have a nice set of wheels with brand new tires on them and I like to drive the truck whenever I can, I will use those for regular duty. It's a lot easier to get them mounted than the originals. I am getting old so the originals with the new tires should outlast me. The only real issue I had is that I ordered the tubes from a local shop that assured me that the valve stems are bendable and should fit fine when in fact they are too short. I had to put extensions in them with a piece of fuel line to protect them from the side of the rim. Minor issue really.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
10-15-2020, 05:52 PM | #1558 |
70+ ( Old Skool Club )
I took my truck for ride and stopped for coffee as it will be going into storage next week for the Winter Months.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-15-2020, 06:17 PM | #1559 | |
10-15-2020, 06:22 PM | #1560 |
Put the new cab mounts in haven't torqued them yet but the cab as of now is 1/4 inch higher off the frame. May come down a bit when I put the torque wrench on it.
10-15-2020, 06:26 PM | #1561 |
Prior to paint
10-21-2020, 07:57 PM | #1562 |
Started installing a Counterpart tach kit. It definitely doesn't fit like OEM, but it's good enough for my truck. I'll be working on the wiring tonight. Sprayed my old faded gauge needles with fluorescent red-orange Rustoleum inverted marking paint. It is flat when it dries, and it matches the original color quite well.
10-21-2020, 10:04 PM | #1563 |
Who Changed This?
Looks like it sprays sideways, too!
10-21-2020, 11:19 PM | #1564 |
10-22-2020, 12:23 AM | #1565 |
That looks like it is made to spray down for locating lines
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
10-22-2020, 12:52 AM | #1566 |
10-22-2020, 02:17 AM | #1567 |
Got my tach wired up. Ran the brown wire through an empty slot in the firewall bulkhead connector and wrapped it inside the engine harness.
10-22-2020, 09:46 PM | #1568 |
I started setting body panel gaps. Looks like their going to need a lot of help. Awesome.
10-22-2020, 11:09 PM | #1569 |
1> Start a preliminary layout of the cab wiring harness. Try to sort out which wiring I will use and which I won't. Might try and repurpose some of the extra ones. Also, I added wiring for control of the passenger pw and pl.
2> Get my nerve up to put the cab on the chassis. (I've been stalling saying I needed to have the exhaust in first. Then it was to have the wiring harness laid out. Both are not complete)
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
10-25-2020, 11:00 PM | #1570 |
Went for a cruise today.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
10-25-2020, 11:21 PM | #1571 |
At the body shop.
New Hella h4 E codes
Replaced the ancient Cibie lights. Sand blast rust and fell completely apart when I took them apart. And scotch brite and comet washed the roof. I think the off white is officially dead.
" That didnt make it any newer " " Dont antique the equipment " |
10-28-2020, 02:36 AM | #1572 |
Dig the headlights, I have Hella sealed unit headlights!
Shocks, I have a dedicated thread, will tell the story there. Discovered a problem...... Also got the heater fan and back-up lights working. I'm too stupid to figure out electrical, had a trusted mechanic do it.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
10-28-2020, 04:27 AM | #1573 |
Finished installing my hidden Kenwood amplifier bluetooth system. After installation, I sensed that it needed a little more bass, so I installed a powered subwoofer that fit neatly right under my bench seat.
Very happy with the results. |
10-28-2020, 11:41 AM | #1574 | |
At the body shop.
Was considering some LED bulbs. But the new not rusty lenses are a huge improvement. And the e code light pattern is neat too
10-28-2020, 12:46 PM | #1575 |
That's kind of remarkable. Classic for sure.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
