#251 |
Re: 67 SWB First Build
update.
pretty minor but exciting update for me. i’ve been talking about spraying feather fill for the last yr and i was finally able to get a couple of coats down on the bedsides. I can already tell i still have lots of sanding in my future ![]() Bed is completely bolted together. I only needed to slot a couple holes with the new floor. I used this 3m strip caulk for the seam between the bed and tubs. It seemed to work pretty solid and from the description it seemed like a good material for the job. Attachment 2030710 Feather fill sprayed on pretty good for my first time. Looking forward to getting everything else in the near future Lastly, I finished seam sealing the bed. Very tedious work with all the taping for clean lines. |
#252 |
![]() Join Date: Sep 2015
Looking good!
#253 |
hey thanks man! trying to stay on it as much i can these days.
#254 |
quick update before the weekend.
i finished getting the cab in feather fill. i only have a few more spots to spray before the sanding starts up again. This body work can be exhausting and seem never ending. hope the end result looks straight ![]() times like this i wished i had a gmc ![]() |
#255 |
Sweet! Nice progress man. And great idea on the tailgate letters I may use that method too.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
#256 |
thanks much. the tape should save some time from unneeded sanding. I know i’ll have plenty of that in my future.
#257 |
I finished spraying the feather fill over a week ago and then jumped into sanding mode. i’ve been trying to get a panel/area done a night. Just a few areas so far that will require some glaze. Hopefully in the near future my updates will include some urethane primer
#258 |
Almost Satisfied
![]() Join Date: Mar 2002
Looking good. Jelly arms when you are done.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#259 |
That’s for sure. Lots to go, still!
#260 |
Small update -
I’ve been spending an hour here and there in the shop when it’s not too hot out. Mainly been working on the hood. It had a lot of flimsiness to it from the rotting hood brace pads. I did a pretty thorough search on here with minimal luck on what to replace it with. Tried using the foam pads but they didn’t work too swell. So I talked to a fella who restores cars for a living and he said i would Be better off using some 1 part sealer every 6” or so. Seemed to make the hood more solid. Hopefully it holds up too well and the hood doesn’t move too much with the fluctuating temps... time will tell. Test fit with the new hinges I’ve had for awhile. They seem to be a nice piece. The manufacturer forgot a couple pieces so i couldn’t hook the gas struts up yet. Hopefully i receive them in the next week or so. Tonight i was able to get the hood in feather fill. Back to sanding ![]() |
#261 |
![]() Join Date: Dec 2009
Great progress.
I like those hinges. Here is an interesting thread about the hood{ link below}. Link:https://67-72chevytrucks.com/vboard/...+dampening+pad .
#262 |
Very nice. And I was thinking about using some of my leftover KILLMAT sound proofing between the hood skin and support rails. You guys think this will work ok? Might have to layer it 2-3 layers it's so thin but I was thinking seam sealer might shrink over time or get too hard with the heat over the years?
#263 | ||
I think your idea could work. I think the key is making sure they can move independent of each other. The hood in my opinion is the most finicky panel for body work. |
#264 |
The missing parts for my hinges arrived this morning. Pretty happy with Summit’s customer service. Once they got ahold of the manufacturer, the parts were over nighted which i was not expecting
![]() Anyways, spent 30 minutes piecing it together and doing a rough alignment of the hood. These hinges are pretty sweet and seem to allow for a tad more adjustment than the original hinges which is nice. They weren’t cheap but i think the money was worth it ![]() |
#265 | |
#266 |
Very nice
#267 |
Thanks. I think I’ll like them ![]() |
#268 |
Last update for the weekend. Before i blow the pickup apart again for the urethane primer and final sanding, i only have a few items left i need to do. One of those items was locating my mirrors. Had my bro over to hold them in place until i liked the location. I used threaded rivnuts to hold the mount in place.
I know these mirrors aren’t for everyone, but they seem to function well and i think they’ll look pretty good when the rest of the pickup is painted. The mirrors came from Ring Brothers, same manufacturer as my hood hinges. Thanks to board member Siggy, the other item on the agenda was not originally planned, but I couldn’t resist ![]() |
#269 |
Coolest update I’ve had to date....
My wife gave delivery to our first kid earlier this week, a healthy baby boy. It’s been quite the adjustment, but digging every moment of it so far. Progress is definitely going to be slowing down a bit which is unfortunate, but I’ll still try to sneak up to the shop when time permits. In the meantime, I’ll continue to look at the build threads to help keep the motivation going and update when i can ![]() |
#270 |
Congrats to you sir!
#271 |
Congrats man!
#272 |
![]() Join Date: Nov 2015
Congratulations... you should be very proud! A handsome baby boy!
Family comes first, the first years are very precious, and you can’t get them back, Enjoy your young family now, the truck will get done in due time, very happy for you and your wife.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
#273 |
Congratulations indeed! That is one beautiful baby and one loyal dog!
I like your mirror choice and the location you chose. Right on ![]()
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#274 |
Little update-
The little guy is 2 months old and boy has it gone fast. I really haven’t had much time in the shop, but between diaper changes I’ve been able to knock a few things out. I saw a few other members on here that had purchased these altman easy latches and they looked like a nice product. After some research on the forum and elsewhere online, I decided to make the purchase. The panel that installs on the door was pretty straight forward to install. Shot them with some primer before i installed them. I’ll seam seal them and the rest of the doors when I tear it all apart again. Early on I purchased some aluminum hexagon mesh for a grill insert. After i completed the shaping and figured out how I would attach it to the grill, i realized I’d lose access to the hood latch handle. After scouring the forum, i found one post about a simple mod that someone did for a similar reason. I decided to make a under the bumper hood latch handle. Cut the handle off and flipped it. Used some small angle iron for a bracket and some steel flat bar as my handle. Here it is mocked up to ensure it worked. I’ll eventually pretty it up a little bit and add some sort of padding/handle latch to the bottom of the core support to prevent it from swinging around while driving. Also, I need to get some new bolts, as i just used what i had laying around to mock it up. Lastly, I purchased a few small items for the interior. Still unsure if I’ll use these cup holders. It’s a nice piece, but I’m still on the fence on whether or not I’ll use my 67-72 seat or if I’ll get something out of a newer rig that has a fold down console/cup holder. I saw this thread and thought it was a pretty cool seat swap. I’ve searched around on CL and market place, but so far i haven’t seen anything. http://67-72chevytrucks.com/vboard/s...ght=King+ranch Until next time! Al |
#275 |
All awesome work man. Really like all these ideas, grill mesh and relocated handle is sweet. I'm in the fence too on cup holders with bench seat. Where do I put them.
