10-25-2020, 02:04 AM | #1 |
Clear coat on a new master cylinder
I just put a brake master cylinder in my 73 Jimmy. After thoroughly cleaning it, I applied 2 coats of clear coat (like I always do) before bench bleeding it.
It occurred to me, not everybody realizes this is an option. I have been clear coating new master cylinders for ...20 years, maybe? I thoroughly clean the outside of the master cylinder with brake clean, let it dry, and spray it with 2 coats of clear spray paint. It ain't perfect, but it does add some level of rust prevention. I have had master cylinders that were [at least] 5 years old with almost zero rust. Anyways just thought I'd share that tip. Results may vary -Russ
Insert clever text here: |
10-25-2020, 08:47 AM | #2 |
Re: Clear coat on a new master cylinder
doesn,t the brake fluid eat the clear ?
10-25-2020, 10:25 AM | #3 |
Moderator
Only if you spill the brake fluid ;-)
I cleared the natural aluminum intake on one of my 350s 25 years ago. Still looks great. |
10-25-2020, 04:41 PM | #4 |
Clear coated many iron masters even back in the day when I was a tech at a Chev dealer ship. The service manager gave me the tip. If you get some brake fluid on it its easy to clean and touch up. Rusty masters are not pretty.
10-25-2020, 05:37 PM | #5 |
I clear coated my original 307 valve covers on my first 68 42 years ago and they never had a hint of rust.
10-25-2020, 09:33 PM | #6 |
I used Eastwood master cyl paint on mine..also painted my calipers with it as wel.so far it still looks good..has a raw cast iron look to it..
Never thought about using just clear...
10-26-2020, 03:11 PM | #7 |
I shot mine with SPI epoxy. Its only had fluid in it for a few months and I don't think I spilled any but it looks great.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
11-09-2020, 12:21 PM | #8 |
I prefer the "patina" look, lol.
11-10-2020, 11:23 AM | #9 |
Yeah.... But AZ has that "dry-heat" so it's only 'patina' out on the West Coast LoL.
11-12-2020, 08:48 PM | #10 |
Use cast blast on iron parts . Summit valve covers are what my builder puts on to dino I've changed them since
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
